Hi there
Quick question - will the 64 bit version of Voyager (Advanced) be able to pick all my “32 bit” patiently generated profiles, setup parameters etc.? Or I am calling for issues here?
Thanks in advance for your advices.
Rodolphe
I just made the switch last week and it was seamless.
Also seamless for me.
Put attention to the drivers you are using for the setup controls. Some devices doesn’t have 64 bit driver or you must select it manually in the profile. I suggest to clone the profile before switching to 64 bit and use the new profile in case you need to change drivers configuration.
If your device (one or more) doesn’t have 64 bit driver the device cannot be used.
Thanks Leo.
So far I should be good to go, all drivers have a 64-bit version.
