New in Voyager Web Dashboard: Flexible Coordinate Input & Automatic Sanitization (v1.2.4 Phoenix)
Hey folks,
just wanted to share a quick update about the new coordinate handling in Voyager Web Dashboard (v1.2.4 Phoenix) Virtual FoV.
I’ve finally implemented a real “sanitizer” for the coordinate input box—now you can paste pretty much any format you like, and it’ll get parsed and converted on the fly.
No more having to remember if you need a dot or a comma, or if you’ve got to use “h m s” or colons or degrees… it’s all accepted, and the system will sort it out for you.
You can throw in stuff like
11:57:35,3 +53:22:24,9
or
186,736°, +41,269°
and it’ll work just as well as the classic
12h 34m 56.7s, -45d 12' 34.5"
or even object names like
M31
and so on.
There’s also a little tooltip now (see screenshot) showing you all the accepted formats—honestly, it covers more than I thought possible. You don’t have to stress about how to write coordinates anymore; just copy and paste them, even from European format (comma decimal notation).
On the technical side: before parsing, the code now automatically converts decimal commas to dots, strips out random degree symbols, and does its best to “guess” where RA ends and Dec starts, even if you forget a separator. There’s probably some edge case I haven’t thought of—so if you manage to break it, you win a virtual cookie and my eternal respect.
This should make centering Virtual FoV a lot more forgiving.
If you want to see it in action, here’s a screenshot:
The version is called 1.2.4 Phoenix (because after wrestling with coordinate formats for days, I felt like something needed to rise from the ashes…).
If you want to check it out, the link with this version is here:
Voyager Web Dashboard 1.2.4 Phoenix
Let me know if you run into any weird edge cases or if you have a format you think should be accepted but isn’t!
And as always, clear skies!
Note: This version is still considered beta—so please use it with a bit of caution, especially if you rely on Voyager for your real imaging runs. I recommend double-checking any critical operations and reporting anything odd you notice. Feedback is more than welcome!
Thank you, Francesco!
Hello
My PC has a problem with Web Dashboard. It keeps presenting this error, then Dashboard becomes unresponsive. I have tried on another PC and v1.2.5 works fine. So I wonder if something on my PC needs updating?
Thanks so much for the wonderful work you are doing on this program!
Adrien Richardson
Thank you Ardien!
Please let me know what s.o. and browser version. Next week we can investigate directly via remote access if you want.
Best regards
Francesco
Adiren had an issue with the router configuration, which I helped him resolve. It was not related to the dashboard. If you have any other issues to report, please feel free to do so.
Hi Francesco
I can never get the camera section and the cooler section to show what is selected in voyager. What am I doing wrong?
Hi Tom,
Thanks for reaching out. Let me clarify the functionality of the Camera section in the WebDashboard.
From its very first version, this section has been designed with a single purpose: to send manual shot commands to Voyager. It allows you to trigger an exposure on demand by directly selecting the required parameters (filter, exposure time, etc.).
This core functionality remains unchanged. The panel is intended for sending commands to Voyager, not for syncing data from it. The only exception is the cooler graph, which is the only element in this section that synchronizes with Voyager’s data.
The design was meant to replicate the functionality of the “OnTheFly” section from the Voyager desktop application.
I hope this helps explain the design philosophy behind it.
Best regards,
Francesco.
Many thanks for your efforts in enhancing Voyager Web Dashboard.
When do you think this enhanced version will be available from Voyager internal web server?
Clear skies
Antoine
Hi Antoine,
when we have enough positive feedback to promove it like new version.
+1 with positive feedback
any update on this
Chris
