NGC 1637 is an intermediate spiral galaxy in the constellation Eridanus, approximately 35 million light years from Earth.
Photographing this galaxy proved quite a challenge, not only because of our light polluted skies but also the galaxy’s apparent size. It is 4x3.4 arcminutes, or about 1/8 the diameter of the moon from our point of view (about 1/15 of the width of your little finger if held at arm’s length). It is also exceedingly dim at magnitude 11.5.
We used 6 telescopes to capture this galaxy. Voyager controlled our 600mm and 400mm systems to capture luminance detail, and Voyager SC Observatory Version controlled our 4-scope 300mm widefield array to capture RGB color. A total of almost 59 hours was captured over a four night period.
Larger version and full details: https://www.masterdarks.com/ngc-1637/
Thats an incredible result Andy … congrats to all MasterDark team. This target is really hard for all …
Thanks for sharing with this forum.
Great image, congratulations!
How can I see this version of Voyager.
( I about to about buy the base version)
Max
Hi Max. Do you mean the SC Observatory multiple-scope version? Do you want to control multiple scopes on one mount? If yes, then contact Leo, the multi-scope requires a different license.
Hello Max, i’ll try to prepare a doc about.
Btw, I just bought the basic - standard version. I have three scopes on two mounts
I am interested in any new automation tools.
I have one feature to ask for the basic version.
My Alnitak Flax box is on the wall. I have is Alnitak that is a cover only( no flat function ). It is on separate USB device. I can only connect one or the other currently.
Max
Thanks Max,
Ok, I’ll add another flat cover device to Voyager.
