Long shot perhaps but has anyone integrated officina stellare osbus control into voyager? Looking to control fans, shutters and heaters in a dragscipt. Leonardo thinks it might be possible to call external scripts (from officina stellare) into voyager if they exist.
Matt I wrote to you to use external dragscript block to call a script done by OS but also to call a script/exe written by you for example using ASCOM driver if they have one
Just to be sure you have understand this, this open so many mode to solve your problem. Otherwise you need a custom development
Thanks Leonardo, very helpful. Only posted on the forum in case someone in the community has already worked out a resolution to this and might save some time working it through!
