Preview of the incoming Orphan Sets and Targets management:
Orphaned Sets and Targets are those that belong to non-existent profiles or that have non-existent or null sequence base.
With this management you can also move Sets from one profile to another and define the change of Base Sequence during the move.
Cooming soon !
Leonardo Orazi
Very nice Leo!
You are so thorough in thinking things through and we get the benefit of that. Advanced is going to be very full-featured for an initial release.
Wohooo, i need it i need it i need it, just changed a CCD on a pre existing optical path and need to transfer my pre-configured shots/targets
Thanks for your helpful work Leonardo
Geremia
Great management! Hopefully this can be used when Advanced Array comes out?
I will reach you @Roberto_Botero directly to inform when the Array version will be started.
Awesome, thanks Leo…
Just had to do this the hard way yesterday as I moved into summer camera cooling
Jon
Hi Leo
I’d be really interested in that array version too - I’m trying to run a 2nd camera with the 2nd instance at the mo and not really getting whether it should work or not ( in a limited fashion) without array.
Cheers
Mike
Array license is needed to manage more than one setup over one mount.
If you have only 2 instance of base you can run 2 setup with 2 different mount.
Advacend + Array = Full License but you must have the Array license.
Full License, I will work about after the Advanced Release.
