Voyager uses the focuser with skyx and skyx uses it successfully with ASCOM driver. NINA uses the ASCOM driver. But when I try to use Robofire with the ASCOM driver I get this message.
Any Ideas?? It seems to be locked of Com6 which it uses on Skyx. I have gone into the ASCOM profile and changed the port number but that does not seem to do any good.
You cannot connect serial port in more than one application. The port is open by another application.
This error coming from the ASCOM driver you are using for focuser and not from Voyager. Close all application usign the focuser also the one from Peagsus Astro and retry, otherwise restart your PC and do not open anything else … just Voyager.
Yeah! It is working. Deleting the SKYX focuser configuration fixed the problem. I will be trying it for real tonight. Thanks-- Leonardo for your suggestion.
Doug
