Can I use dither in PHD with long deep sky exposures with a QHY168 camera? Similar to how BYEOS does it?
Thanks for looking
PJM
Thanks for looking
PJM
Absolutely, you can.
Kind regards,
That’s good to know Glenn. I have a MX+ mount controlled by TSX and a Orion SS auto guilder. I haven’t tried Voyager yet, but if it can do proper dithering with the QHY168, I will give it a try.
Mahalo, PJM
Yes, it works fine. I found you need to make sure the settle time after the dither is long enough for things to stabilise. I use a long PHD2 integration time and had some weird problems until I fixed it
