So after many years using MAXIM DL, then many years on SGP, I’ve decided to give Voyager a test run. However, can anyone advise if it supports the Planewave PWI3 focusing software? Having installed and started to configure, it doesn’t look to be the case and I may have to revert back to FocusMax unless I’m misreading the label and contents.
thank you
Voyager support the PWI focuser, for autofocus we have ROBOFIRE, our internal autofocus system based on single star or on multi stars/localfield. That are the most advanced autofocus system on the market.
List of supported autofocus are here if you dont like it:
https://wiki.starkeeper.it/index.php/AutoFocus_Setup#AutoFocus_Choice
PWI Autofocus is not supported by Voyager.
Fabulous, thank you for the very prompt response
