After connecting to devices (simulated or real devices), I am trying to plate solve an image captured by SGPro last year using “Plate Solve FIT” (Solving Reference FIT) from OnTheFly window and I get the following message:
Run-time error ‘6’: Overflow
The PlateSolve2 window displays RA/Dec correctly from my FIT file but it shows 0x0 next to arc minutes button.
I am able to successful plate solve this image with Plate Solve 2 if I run it from the “Setup” window and under “Plate Solve” tab. I click on Setting button and Plate Solve2 window pops up, I manually open the FIT file from Plate Solve2 window and clicked on “Plate Match” button and it solves within a few seconds. Also it shows 44x35 next to arc minutes button.
I think the source of the problem is when Plate Solve2 window shows 0x0 next to arc minutes button if running “Plate Solve FIT” (Solving Reference FIT) from Voyager’s OnTheFly window.
Here is a FIT file I am trying to plate solve with Plate Solve2 from OnTheFly window using “Plate Solve FIT” (Solving Reference FIT) feature:
I don’t think it has to do with SGP. All SGP did was captured the image in FIT file. I uploaded the FIT file for you to evaluate the FIT header and see if anything is missing that Voyager needs. Have you tried to evaluate my FIT file?
I tried to blind solve from within OnTheFly windows and was not successful. About 2/3 completion of uploading to nova.astrometry.net, it aborted due to internet error. I’ve tried 3 times without success.
You need to download the FIT file first before looking inside the FIT file.
I found a strange data format in your FIT header that cause Voyager to calculate FOV with infinite value results … this create a OVerflow error in PlateSolve2. Now is to late for me… tomorrow i’ll try to understand better. This is from the log in Voyager:
The strange part is from within Voyager in Setup window under “Plate Solve” tab, I clicked on Settings button (left of Download Catalogs button), Plate Solve2 window pops up. Then I manually open the FIT file from Plate Solve2 window and it successfully plate solves within 2 seconds. Also, it displays 44x35 next to arcminutes button instead of 0x0.
