Hi all
it would be very useful to allow a target’s angle to be set, and to then have the plate solving to include rotation correction
This would support the following use cases
- Precise positioning to place a guide star on the guiding chip
- Orientating to align with an old data set
- Framing that been established externally
Nicholas,
I have requested the same feature and, as Leo said, it is on the To Do list.
In the meantime, here is a workaround. At the beginning of your imaging session, open the OnTheFly panel and click Plate Solve Actual Coord. After the solve, in the monitor section, you will see within the solved coordinates a camera rotation angle. Compare this to your desired angle and rotate the camera by the necessary amount. Solve, rotate, and repeat until your camera angle is within the desired range.
Kind regards,
So many thing to do sorry !
Nothing to be sorry about Leo, you and Roland are doing a brilliant job
cheers
Nick
Thanks Glenn for raising the original request, and for the handy tip!
cheers
Nick
