Plate solving via Astrotortilla
I’m just starting to explore the Voyager software. In my current setup I use Astrotortilla. Any chance of integrating with that? It uses a local installation of the astrometry.net software. So, if not Astrotortilla, what about the local astrometry software (it runs under cygwin)?
Hi and welcome,
Voyager using All Sky Plate Solve from G.Benintende. A COM/App based on Atrometry.net Local Server. You can use it for plate solving and blind solving:
http://www.astrogb.com/astrogb/All_Sky_Plate_Solver.html
Astrortilla will not be imported.
All the best,
Thanks for the reply. I’ll investigate the All Sky Plate Solver then.
Its really simple to install. Just run setup and download index from astrometry. Probably you already have index and linux environment in pc
Yes, it’s downloading the index files again, because it didn’t like the files I already had installed. It doesn’t matter since if I get it all working, I’ll just remove Astrotortilla and the “old” files.
