Platesolve and Mount Simulator
I have a FIT recording and would like to get involved with the Platesolve. Unfortunately I can’t get a proper platesolve. Which settings do you use. However, I only use the Mount Simulator. Is it maybe because of that? Greetings Enrico
Plate solve need a real image or not work. SO use a simulator that give to you real image or use the plate solver simulator of Voyager:
https://wiki.starkeeper.it/index.php/Plate_Solve_Setup#Voyager_Manual_Simulator
I have a real picture about OnTheFly - Platesolf FIT. tested. It never leads to success. I use ASTAP. It always says “Plate Solving Error : File FIT doesn’t contain(s) XPIXSZ/YPIXSZ/FOCALLEN/OBJCTRA/OBJCTDEC Key to Plate Solving” …
Do not put link to external service please !
You cannot solve a non referred FIT with a normal plate solving.
This is one of the fundamentals info to know about plate solving.
Otherwise use a blind solve service.
Many Thanks. Is there a good tutorial that explains Platesove? Greetings Enrico
I suggest you a search on google or in a general AP forum.
