Before you try a sequence, master on the fly actions. Then add a sequence. Then after you master that use a dragscript.
But most of your actions will be here:
https://wiki.starkeeper.it/index.php/OnTheFly
Also note that you can park, start and stop tracking with the status/commands widgets on the right side of the screen. You can also do manual focusing and other actions depending on your equipment. There’s a tab to switch between status and commands.
https://wiki.starkeeper.it/index.php/Status_Window
Connect equipment- Startup - Voyager Wiki >section>startup> connect (after you added all your equipment, then press connect.
Slew to manually selected star for focus check - you can click on your object in Stellarium (or setup another planetarium in Voyager) then go to the object finder: section>on the fly>screen icon to the right of “fast find” the press get selection (this will copy the coordinates here), then press use, that will populate the coordinates to the go to section. After that you can press “precise pointing target coordinates” in the on the fly tab. That will slew your scope to the selected coordinates and plate solve/sync and then keep trying that until the target is within the specifications you put in the setup window.
Manual focus using bahtinov mask - on the fly> camera shot. Setup your exposure by pressing the gear icon. View your image with the fit viewer. Make sure to enable that in setup.
Select imaging object - on the fly- 1) try searching in the target box and press fast find, or use the object finder as noted in the
Framing -for this you need to use the paid version and use the web dashboard. It’s a great and easy tool to frame.
Plate solve -a plate solve and sync is built in with the precise pointing target coordinates. You can also load a fit and plate solve that and do a goto if needed.
Sequence to capture data -use the sequence tool.
Cool camera -widget
Park scope-widget
So to recap try everything on the fly first. Then when you understand that, utilize a sequence with the sequence button and create a sequence. Within the sequence, you can have it point do a precise go to, adjust your camera temp, setup guiding, then your sequences, park . . .
https://wiki.starkeeper.it/index.php/Sequence_Configuration
Then after all that use a Dragscript! It’ll do everything for you:
https://wiki.starkeeper.it/index.php/DragScript
