Question on emergency suspend / resume
Hello,
using dragscript and assuming that emergency suspend is the result of clouds passing over, I assume you would have the following script events after emergency suspend : Stop Guiding, Stop tracking, Park Mount, maybe more (shutdown camera etc…)
On emergency resume, I assume you just would need to Unpark Mount, maybe Start tracking. I assume you don’t need to indicate Start Guide as it will return to a sequence with Guiding enabled, no Goto needed I also assume.
is this generally how you would set this up ?
Thank you
I think best is to park mount, this will stop tracking. Stop guiding / shot / focuser etc will be done by the sequence. At resume unpark the mount, the sequence will do all the rest for you. Obvius If you close the roof remember to open.
