The is no method available to take images using the RBI mode in Drag script.
I tried to take Dark and Bias.
Max
Max
RBI (attention to use) is related to your camera not to Voyager.
Read out mode is missing
RBI is an option of the driver not related to readout mode, usually all the cameras have a set dedicated also because if you decide to use you must leave on for all kind of shot.
Dragscript editor doesn’t have access to profile configuration, for this reason you dont find setting about readout mode and speed in exposure block. Exposure block use auto mode of readout mode and default speed mode. This mean chooses are based on shot type and binning. It retrieve automatically the correct values you set up on Voyager camera setting tab.
Thanks. Now I understand
Max
