Hello everyone!
I have put together a sequence block for my array with two knots. It is supposed to take Ha-images the given sequence for two hours. After two hours, if everything is OK, the setup should be disconnected, as well as the array connection, and then both connections should be re-established. This is necessary because I apparently have a problem with a stable connection between the two knots. If the connection is lost and the slave no longer takes images, this should be remedied at least after two hours. Then the sequence should be restarted. Until 03:50 a shutdown should be initiated there.
The whole thing works - only the part with “repeat until time” does not. The sequence was still running tonight at 4:30 am. Where is my error in thinking?
All the best,
Markus
