Research Sequence: Add Constraints?
Hi Leo,
I noticed that the Sequence Configuration under the Sequence tab there are “Sequence Constraints” to choose to "Exit Sequence if Target is below or above altitude and/or Hour Angle. Could these same constraints be included in the Research Sequence Tab?
Thank you very much for your consideration.
Best Regards,
Russ
Hello Russ,
Research Sequence tab already have altitude constraints but not the HA constraints. Running in loop usually the Altitude is good enough to manage targeting. We can check if adding HA constraints could be compatible with the actual algorithm.
Leo,
Oh! I missed that. That is all is needed. Thank you.
Russ
Hello, I’ve been using the target altitude constraint for mosaics. The problem it seems is that this is only checked between targets, not during a sequence? This causes the target sequence to sometimes continue well past the minimum altitude depending on number of shots.
Is it possible to add sequence constraints to Research Survey?
Yes, it’s possible.
Added to the to-do list.
That’s awesome, thanks Leonardo!
