Hi all.
There is a setting in the RoboFire Configuration Vcurve Mode section “Camera Parameters” Bit/Pixel". I currently have 16 as the figure, My Asi 1600mm pro is 12 Bit ADc , should I change setting to 12bit. What does this setting do.?
Thankyou
Hi all.
Thankyou
Please, put the bit resolution of the data as send to Voyager by the driver.
Usually is 16 bit. Some drivers works at 12/14 bit and rescale internally the data to 16 bit, someone (really rare) leave the data at native bit resolution in this case you must put the native resolution. If you have an ASI camera and using a native driver in Voyager the value to put is 16bit.
