Hi Leo, All
I am having an issue when trying to acquire a star for guiding (or for calibration) using PHD2 v2.6.6 and Voyager 2.1.2e. This error was not present in 2.1.1j. Logs attached for reference.
Basically, if I calibrate or start guiding manually, PHD2 works just fine. But if I let DragScript run through its paces and try to calibrate or start guiding using a previous calibration, Voyager 2.1.2e exits with an error stating:
For calibration star acquisition: Calibration Guide : Calibration Start Failed (Object reference not set to an instance of an object.) See 00:13:22 424 in 2019_05_24_Voyager.log
For guiding star acquisition: Start Guiding Error (Start Guide Failed (Object reference not set to an instance of an object.) See 00:29:25 713 in same file
During this same session I reverted back 2.1.1j and the issue went away.
I am also providing another Voyager log to show my 2.1.2e settings (2019_05_23) and two PHD2 logs also to show settings and the messages from the PHD2 server.
2019_05_24_Voyager.log -
2019_05_23_Voyager.log -
PHD2_DebugLog_2019-05-23_223452.txt -
PHD2_DebugLog_2019-05-24_003344.txt -
and I could only find 2.1.1j. I’ll try 2.1.2 today if it stays clear.
