I’m having some problems with Robostar focus (see below). The routine ends in error, though local field works fine. What am I overlooking that’s causing the focus routine to fail? Thanks in advance! David
-----------log------------
19:38:50 115 - For your info the Best Performance obtained from your Mount in this pointing is 00∞ 00’ 14"[DMS]
19:38:50 115 - Precision Point In Accepted Range
19:38:50 146 - Action Time [PRECISE_POINTING] => 0 [m] 40 [s]
19:38:50 146 - Action Time Mobile Mean [PRECISE_POINTING] => 0 [m] 53 [s]
19:38:50 209 - Defined (JNow) Center of Dithering at RA=03 47 31.865 DEC=24 09 27.04
19:38:50 240 - Focus Requested, Start Procedure
19:38:50 318 - Start Sequence-Focus with Voyager RoboStar Acquire Star and return
19:38:50 318 - RoboStar Search J2000 RA 03 46 06.413 DEC 24 08 48.52 ; Magnitude=4-7 ; Radius=2[∞] ; Min Altitude=35 00 00.00 [∞] ; Separation = 0.5[arcmin] ; Transit Side = BEFORE
19:38:50 490 - Action Time [FOCUS_SLEW_STAR_BACK_TARGET] => 0 [m] 0 [s]
19:38:50 490 - Action Time Mobile Mean [FOCUS_SLEW_STAR_BACK_TARGET] => 2 [m] 6 [s]
19:38:50 506 - Change RoboStar Star and retry focus !!
19:38:50 552 - Focus Requested, Start Procedure
19:38:50 568 - Start Sequence-Focus with Voyager RoboStar Acquire Star and return
19:38:50 580 - RoboStar Search J2000 RA 03 46 06.413 DEC 24 08 48.52 ; Magnitude=4-7 ; Radius=2[∞] ; Min Altitude=35 00 00.00 [∞] ; Separation = 0.5[arcmin] ; Transit Side = BEFORE
19:38:50 662 - Action Time [FOCUS_SLEW_STAR_BACK_TARGET] => 0 [m] 0 [s]
19:38:50 680 - Action Time Mobile Mean [FOCUS_SLEW_STAR_BACK_TARGET] => 2 [m] 5 [s]
19:38:50 685 - Change RoboStar Star and retry focus !!
19:38:50 724 - Focus Requested, Start Procedure
19:38:50 767 - Start Sequence-Focus with Voyager RoboStar Acquire Star and return
19:38:50 818 - RoboStar Search J2000 RA 03 46 06.413 DEC 24 08 48.52 ; Magnitude=4-7 ; Radius=2[∞] ; Min Altitude=35 00 00.00 [∞] ; Separation = 0.5[arcmin] ; Transit Side = BEFORE
19:38:50 959 - Action Time [FOCUS_SLEW_STAR_BACK_TARGET] => 0 [m] 0 [s]
19:38:50 974 - Action Time Mobile Mean [FOCUS_SLEW_STAR_BACK_TARGET] => 2 [m] 2 [s]
19:38:50 987 - Max number of Focus Retry reached … sorry !!
19:38:50 994 - Sequence-Focus with Voyager RoboStar Acquire Star and return finished with problems (RoboStar Search Error (FindStar):Could not find file ‘E:\Voyager\VoyFocStar.mdb’.) !
