Hi all,
I successfully installed Advanced on my second rig - tonight was the first clear skies.
While my dragscript reached the “robotarget block”, I got the message : Scheduler did not select any targets… and robotarget reject reason was showing the following: “Scheduler Candidate Interval INVALID”. ;(
I just removed all the constraints and put them back and after having manually started “RoboTargetRun” everything was okay. Did you ever encounter such message ? Just want to make sure that it won’t fire back.
Thank you and clear skies,
Aygen
