Running Viking Instance 2 from command line
Hi all. Apologies if I am being blind as I could not see this. What is the command line to launch Viking.exe as the second instance?
I have Viking running 2 cards, and have 2 licences. On instance 1 I have the Multi-Instance tab, and the Launch Instance 2 works fine. However the button to add a new instance 2 icon on desktop does not work (on either UI). So need to add manually!
Thx!
Probably you have wrong permissions about Viking on your OS or it do not start it like admin.
Shortcut for desktop:
“C:\Program Files (x86)\Viking\Viking.exe” /instance:2
Base dir:
“C:\Program Files (x86)\Viking”
Thanks Leo. Will take a look (and maybe reinstall). But useful to create the shortcut if needed.
