Hi guys,
I was out last night imaging, due to my terrible climate, clouds often interrupt play during the phase where im capturing my light frames.
Its probably my lack of knowledge but i found myself having to restart the sequence, which meant i had to start the robofocus routine, guiding & also restart the light frame captures.
Is there a way that i can on error, just select a guidestar & resume from the light frame capture stage of the sequence?
All of this is done using on the fly - im not at the stage where i am competent to use dragscript yet
Many thanks
Andy
Hi Andy,
check this( look at this button)
https://wiki.starkeeper.it/index.php/OnTheFly#Running_a_Sequence
Hi Leo & thanks!
I knew it was my lack of knowledge. That’s fabulous & i’ll definitely be using that from now on!!!
What a piece of software you have built!
Cheers
Andy
