Simbad coordinates
I put a target in and use simbad to find coordinates. This is what I get. The RA is messed up. It was working fine till tonite. image
I did the same, got the same results, clicked okay and Voyager displayed this:
Sorry I don’t understand what’s the problem ?
RA can be expressed in degrees or hours; there are 360 degrees or 24 hours in a day and you can convert back and forth.
359.35° RA is equivalent to 23h 57m 24s, it is just a different notation. :slight_smile:
This is the Raw data from Simbad, i leave unchanged before import in Voyager. Nothing changed in code since i have developed first time.
If you also put this value in target RA and DEC field work, for your info.
Well I feel really stupid. For some reason I always thought that simbad displayed in hours, minutes …I thought that I may have accidentally changed some setting.
Thanks for the help.
Mike
Mike not a problem really … thanks to you. You are welcome.
