Hello
I set up a sequence as attached
Everything goes by the book but the rotator is not moving to the position inserted
The rotator is connected by Ascom
Do I do something wrong?
Hi Nikos,
settings are correct in this image. Check your rotator system if there are some faults.
Looks that the manual mode is working fine.
In rotofoc software is working ok and also when I change it from Voyager.
Somehow is not moving through the sequence…Any idea ?
HI Nikos,
best idea is to ask official support. Seems you have something misconfigured in your sequence.
About how to ask support:
Thanks, Leonardo…I will send you there
