I am new to Voyager, but have read and searched quite a bit on this without luck…
I’m using Telegram under Signals in DragScript to message my phone as needed - works very well - great system! All you need (after setting up Telegram outside of Voyager) is to enter your API ID and CHAT ID - along with configuring the message you wish to send.
My question has to do with the two ID’s that must be entered for every Telegram message in a DragScrip. I have not found any place in setup (e.g. under Voyager tab) where I could store these and then autofill? Am I missing such a facility?
I suppose after I work with Voyager long enough, and have built my “standard” scripts - it will not be that big a problem. I’m just trying to make sure I’m not missing something obvious.
