Hi friends!
I’d like to control the fans on my telescope. There is an ASCOM driver for it, but I’m not sure how to integrate that with voyager. Basically I want to set the fan speed on startup / beginning of the night, change it right before starting to image and shut them down at the end of the night.
How can I achieve this?
Voyager do not use ASCOM switch control inside directly … this kind of drivers are not reliable.
For this task we using a companion of Voyager called Viking, check if your I/O card are supported otherwise you can create an external script to call in DragScript in Voyager or ask for a custom development using the support email
https://wiki.starkeeper.it/index.php/Viking
https://wiki.starkeeper.it/index.php/Viking#List_of_Supported_I.2FO_Cards_and_Automation_Protocols
this is the fan control of the RCOS TCC - As I understand this is not supported via Viking (yet?)
Is not supported by Viking.
