Training program for Voyager?
Has anyone setup a training program for users of Voyager and Viking? Did you train them on the web Dashboard or the standard interface?
I am setting up 10 Personal Remote Observatories (PRO’s) next year at our dark site in Arizona, and will have to train each owner of the PRO on the operation of the observatory. Voyager and Viking is the control system for the observatories. All of the folks who are buying the PRO’s are experienced imagers.
I’d be happy to work with someone in the group, and share the results back with the group.
Blaine
Matt Dieterich works with Voyager customers as part of his job in planning, install and setup observatories with inside our applications (Viking and Voyager).
You can ask about if he are interested in doing this.
Thanks, I will try to contact him.
Blaine
Hello Blaine. can I reach out to you privately about the project in AZ? that’s where I live.
Yes, my email is bjmccoy50@mac.com
Hi, The training has gone well. Below is the document I’ve used to train the users on the operation of their observatory. I tried to attach the PDF of the document, but that did not work out. If you are interested I can email you a copy.
I also have the new owners log on to my system to get them use to the process.
So far the new owners are very happy how easy it is to use compared with their system.
Blaine
Using the PRO control PC to Image at CSV remotely
You will be using a Master Drag Script that was created for the Personal Remote Observatory.
This script handles the operation of the PRO.
The Sequence Configuration under the On the Fly tab of Voyager has be used to define targets to capture with Voyager.
You will be editing a predefined sequence that is set up for CSV. The sub’s are 120 sec long.
If you want to create/edit a new Drag Script: See how to manage the Master Drag Script and Sequence Documentation.
Log on to your remote PRO via:
AnyDesk :
Click on the AnyDesk icon on your laptop or home PC/MAC.
Enter the Remote PC number at the upper left corner of AnyDesk app.
This will take you to your remote PRO control computer.
Google Remote Desktop :
Once you are log onto your remote PRO PC:
Click on the Voyager icon that is on the upper top right corner desk of the PRO control computer.
The Voyager/Viking applications will open.
To use the Master Drag Script:
Click on the Section Tab that is at the upper left of the Voyager screen.
Click on the DragScript folder
Click on the Orange Gea r (next to Edit Script button - British Flag)
Choose the CSV Master DragScript and press the Open button.
The Preprogrammed script is loaded and is grayed. You can’t edit
or changed anything on this screen in this mode.
Notice that line 9 says: Sequence with a Start and End and
Sequence - Imaging Target (i.e. M33)
To image the same target as you did the last time you used your PRO.
Press the Run Drag Script button that is at the lower right of Voyager screen.
This will start your imaging run.
To change what you are going to image, you need to change the Imaging Target on line 9.
Press the Edit Script button to edit/change the Master Script.
A new window will open with a white background will open that will allow you to
You will ONLY want to change line 9 by clicking on the line 9.
A Sequence Editor dialog box will appear, this will allow you to change the imaging target for this session. We will use RoboClip to change the target.
Press the RoboClip button in lower left corner of screen. Choose a new target or add a target. After that press Use Selected Target button, to return to the Sequence Editor dialog box.
The old target in the Sequence Editor should have ben replaced by the new target from RoboClip.
If the new target is correct press the OK button at the bottom right of the Sequence dialog box.
After the Sequence dialog box closes, you will be back into the DragScript editor.
Check that the target that is on line 9 is the desired target.
You will now have to save changes that were made, click on the Disk icon to save the change.
Press save button and allow the change to be saved.
Replace the current (old) CSV Master Drag Script with the one you just created.
After the save is completed, you will be returned to the Editor screen.
You need to exit the editor by clicking on X at the top right hand of Editor screen.
The information on the gray screen is outdated and you must press the Reload Script button next to the Edit Script button to use the new target.
After the script is reloaded, you may now run the script by pressing the DragScript Run button.
When you setup these observatories is the assumption and general practise that the hardware attached doesn’t change over time ?
How well your users cope when it does ?
So far very well, we just brought up our 8th observatory. The users like that the systems just work. The most common comment is “I’ve gotten more data in a week time then I did all Summer”.
As far as hardware changing, the observatories are identical which make programming them easy and increases the useable of the system. Of course this is all due to Voyager and Viking.
Blaine
