If you use Tsx and Tpoint , am I correct in assuming you can not do a closed loop slew because Voyager gives a warning “can’t sync mount”?
Seems strange you can’t use the power of Tpoint with Voyager.
Arthur
Arthur
Dear Arthur, Tpoint is just a pointing model engine and have nothing to do with Voyager that cannot manage it.
Not sure I have understand exactly what you mean but with a mount having a pointing model running that not support point refine adding by sync (like TPoint) you must remove the sync request in Voyager Not Sync (Pointing Model Running):
https://wiki.starkeeper.it/index.php/Mount_Setup#Management
I hope this helps
Do what Leo suggests and it all works together wonderfully. You can also set Voyager to do unguided dithers, in the sequence guiding tab.
Thanks gentlemen, all good now.
Arthur
