I would like to request an unguided dither.
I don’t understand how realign to target after X minutes can do this.
Perhaps the same camera that is doing the image can be selected in PHD or MaxIM?
Max
Max
Dear Max , unguided dithering is already on Voyager from the beginning.
Use dithering flag and define parameters in your sequence configuration.
Realign target after X minutes is to avoid shifting of target if you use unguided sequence and/or if you use LocalField Focus which doesn’t do a retargeting like the RoboStar focus.
Dependes on your camera driver if can be connected to more than one camera control system, refer to your brand camera support documentation. Usually an imaging camera is connected only in one place during automation.
