Hello. I am using Voyager for a couple of months with great results both in France and in Chile…
One of my setups in France is in fact a double setup and I bought a 2-nodes license for it. I want to run the 2 nodes on the same PC : master and slave.
The only issue I am facing is that the two setups use ZWO EAF focusers. When I select Focuser EAF 1 and set it up to match the focuser on setup 1 on the master installation, everything works fine. When I select Focuser EAF 2 on the slave install, it looks likes it’s ok but when I edit the settings again I notice it defaults back to the first focuser… In short : I can only use one of the focusers…
I see two options right now. Add a computer to manage the second setup or replace one of the focusers with a different brand…
Could this be fixed in Voyager? That would help me save around 300€! Thanks,
Cedric
