When using On The Fly, I have a sequence that I’ve manually selected in the sequence directory. Is there a way to populate the Slots with that information? I’d like to check and perhaps adjust my exposure times.
Hank
Hank
: Click the top gear icon to bring up the Sequence Configuration dialog. See the Sequence Configuration page for more information on creating a sequence
https://wiki.starkeeper.it/index.php/OnTheFly#Running_a_Sequence
Sequence Editor: Open the Sequence editor - note, as of Voyager 2.0.14e (daily build) and 2.1.0 (stable) you no longer need to have equipment connected to use the Sequence editor
https://wiki.starkeeper.it/index.php/Main_Window#Tools_and_Editor
I already have a saved sequence. How do I open the saved sequence to make adjustments?
Please read the previous post that explain how to open the sequence editor
Open the sequence editor, load the sequence , edit it and save it. Restart the sequence if it is running to apply the changes
