Viking 1.0.32 Release - Built 2023-05-23
Ready to download Viking Release 1.0.32:
https://www.starkeeper.it/viking/Viking_Setup_1.0.32.zip
⦁ [New] UPowerBox 2 Unity REST API → Added AutoDew management with selection of the type of automation and level of aggressiveness
⦁ [New] UPowerBox 2 Unity REST API → Added possibility to set the output voltage of the ADJ OUT (WARNING !!! be careful not to set values that are not compatible with the connected device and damage it)
⦁ [New] Pocket Powerbox ADVANCE Unity REST API → Added AutoDew management with aggressiveness level selection
⦁ [New] Pocket Powerbox ADVANCE Unity REST API → Added possibility to set the output voltage of the ADJ OUT (ATTENTION !!! be careful not to set values that are not compatible with the connected device and damage it)
⦁ [New] Pocket Powerbox MICRO Unity REST API → Added AutoDew management with aggressiveness level selection
⦁ [New] Pocket Powerbox MICRO Unity REST API → Added possibility to set the ADJ OUT output voltage (WARNING !!! be careful not to set values that are not compatible with the connected device and damage it)
