https://software.starkeeper.it/index.php/download/
So much improvments and changes and the version jump to 2.1.0 one decimal power forward.
Big effort done… please renew your license support for Voyager development to allow project to be always better.
Really Recommended to all !
In this version:
NEW => New Status Widget available for viewing the “Observing Conditions”
NEW => Voyager is now able to receive “Observing Conditions” from I/O cards via Viking
NEW => New “Observing Conditions” type control
NEW => Voyager is now able to receive “Observing Conditions” from ASCOM Drivers (including OpenWeatherMap)
NEW => New “SQM” type control
NEW => Voyager is now able to receive SQM data from SQM-LU or SQM-LR or SQM-LE via ASCOM Driver
NEW => It is possible to mix Observation conditions and SQM data in override through decision flags to avoid data overlap
NEW => Added FIT header data on Observing Conditions, SQM, Weather conditions, focuser, rotator and mount
NEW => Added new block in DragScript for the creation of customizable decimal numbers
NEW => Added new block in DragScript for modifying decimal numbers
NEW => Added new block in DragScript for the comparison of decimal numbers
NEW => Added new block in DragScript for the recovery of Decimal Numbers from Observing Conditions
NEW => Modified External Script block in DragScript to possibly save the STDOUT on numbers Decimals DragScript with conversion
NEW => Added new DragScript block to retrieve data on the temperature read by the focuser or Autofocus system
NEW => Added new DragScript block to retrieve the latest Autofocus HFD data
NEW => Added to the “Hallo Northern Sky” planetary control as managed
NEW => Added general option paired with the sequence mode to repeat all configured slots for a configurable number of times
NEW => Added color synoptic chart of the temporal distribution of the filters and of the repetitions of the slots as the shots in the sequence will be carried out
NEW => Added in the DragScript editor to the list of preloaded those mentioned and discussed in the Voyager Wiki
NEW => In the Search and Survey sequence it is now possible to import targets and related data from an external CSV file
NEW => Added in the DragScript editor the command to save a text format file to be printed with the script listing
NEW => In the DragScript suspend event it is now possible to manage the timeout as well as absolutely also for relative time interval and astronomical night end
NEW => New “Safety Monitor” type control
NEW => Voyager is now able to manage Safety Monitor information from ASCOM Drivers
NEW => The Safety Monitor which indicates Unsafe can be configured for emergency exit or for emergency suspension with Safe Resume
NEW => Added SafetyMonitor status LED in the Status Bar before the Application Server Status LED (off = not configured, red = No Safe, green = Safe)
NEW => The connection / disconnection paradigm has been changed it is now possible to make connections / disconnections of individual controls [in this daily build only the SafetyMonitor]
NEW => The Voyager sections are now always operative even without having connected the setup
NEW => Added block in DragScript to connect only the SafetyMonitor control. Useful for monitoring favorable conditions before connecting the whole setup if only the safety monitor is used
NEW => Sequences are now associated with the loaded Setup Profile
NEW => Thanks to the association with the profile the Sequences can be created / modified even without being connected to the setup
NEW => There is an automatic tool to select the sequence of the sequences to be used for their editing (Automatic to the current profile, leaving the original profile, manually selecting the profile)
NEW => Thanks to the automatic tool for selecting the Sequences profile it is possible to edit a sequence of another profile without loading it from a profile
NEW => Added to the Tools menu also the Editor Sequence, the Sequences can be managed even during the execution of Actions
NEW => What has been done for the Sequences regarding the Profile is also applicable to the Search & Survey Sequences
NEW => The Flat Sequences are now associated with the loaded Setup Profile
NEW => Thanks to the association with the profile the Flat Sequences can be created / modified even without being connected to the setup
NEW => There is an automatic tool to select the profile of the Flat Sequences to be used for their editing (Automatic to the current profile, leaving the original profile, manually selecting the profile)
NEW => Thanks to the automatic tool for selecting the Sequenze Flat profile, it is also possible to edit a profile profile from another profile without loading it.
NEW => Added to the Tools menu also the Flat Sequence Editor, the Flat Sequences can be managed even during the execution of Actions
NEW => Added new block for dither not guided in DragScript
NEW => Added Application Server to the rest of the commercial versions of Voyager, which can be activated from Setup on the Voyager Box Application Server tab
NEW => Added NewFITReady Event for the realization by some users of customized FITViewer and Data Analyzer
MOD => Added Int16 as the data type allowed in FIT headers for focal length. In PlateSolve2 the FIT resolution failed if the file was saved with a particular external automation program
MOD => The external script block has been extended to optionally save the STDOUT return text in a Decimal DragScript
MOD => The block of Dragscript for pointing AltAz can now forcibly simulate the required aiming by transforming the indicated position into RA and DEC
MOD => Added parsing event Calibrating in the communication protocol with PHD2
MOD => Added confirmation questions for the creation of modified and unsaved scripts during the rest, the loading and closing of the Editor
MOD => Added Flag in the Unguided Dithering Block to use the current position in case of original blank position value
BUG => Incorrect management of the Time Start and Time End for some time intervals, recreated from scratch management of the timing
BUG => Incorrect indication of the counter / string not yet defined in the DragScript variable handling blocks
BUG => Dome mode was reset if chosen Ascom Dome or Ascom Dome ConnectionLess
BUG => Information about the configured controls was incorrectly removed if the controls were connected and changes were made to the Voyager setup
in questa versione:
NEW => Nuovo Widget di Stato disponile per la visualizzazione delle “Observing Conditions”
NEW => Voyager è da adesso in grado di ricevere “Observing Conditions” da Schede di I/O tramite Viking
NEW => Nuovo Controllo di tipo “Observing Conditions”
NEW => Voyager è da adesso in grado di ricevere “Observing Conditions” da Driver ASCOM (compreso OpenWeatherMap)
NEW => Nuovo Controllo di tipo “SQM”
NEW => Voyager è da adesso in grado di ricevere dati SQM da SQM-LU o SQM-LR o SQM-LE tramite Driver ASCOM
NEW => E’ possibile mixare dati di Observing conditions e SQM in override tramite flag decisionali per evitare sovrapposizioni dei dati
NEW => Aggiunti dati header FIT relativi a Observing Conditions, SQM, Condizioni meteo, focheggiatore, rotatore e montatura
NEW => Aggiunto nuovo blocco in DragScript per la creazione di Numeri Decimali personalizzabili
NEW => Aggiunto nuovo blocco in DragScript per la modifica di Numeri Decimali
NEW => Aggiunto nuovo blocco in DragScript per la comparazione di Numeri Decimali
NEW => Aggiunto nuovo blocco in DragScript per il recupero di Numeri Decimali dalle Observing Conditions
NEW => Modificato blocco External Script in DragScript per eventualmente salvare lo STDOUT su numeri Decimali DragScript con conversione
NEW => Aggiunto nuovo Blocco in DragScript per recuperare i dati sulla temperatura letta dal focheggiatore o dal sistema di Autofocus
NEW => Aggiunto nuovo Blocco in DragScript per recuperare i dati di HFD dell’ultimo Autofocus
NEW => Aggiunto al controllo planetario “Hallo Northern Sky” come gestito
NEW => Aggiunto opzione generale in coppia con la modalitĂ di sequenza per ripetere tutti gli slot configurati per un numero configurabile di volte
NEW => Aggiunto grafico sinottico a colori della distribuzione temporale dei filtri e delle ripetizioni degli slot cosi come verrano effettuati gli scatti nella sequenza
NEW => Aggiunti nell’editor del DragScript all’elenco dei precaricati quelli menzionati e discussi nel Wiki di Voyager
NEW => Nella sequenza di Ricerca e Survey è ora possibile importare i target e relativi dati da un file CSV esterno
NEW => Aggiunto nell’editor DragScript il comando per salvare un file in formato testuale da stampare con il listato dello script
NEW => Nell’evento di suspend del DragScript è ora possibile gestire il timeout oltre che in modo assoluto anche per intervallo relativo di tempo e fine notte astronomica
NEW => Nuovo Controllo di tipo “Safety Monitor”
NEW => Voyager è da adesso in grado di gestire informazione di Safety Monitor da Driver ASCOM
NEW => Il Safety Monitor che indica Unsafe può essere configurato per uscita d’emergenza o per sospensione d’emergenza con resume al Safe
NEW => Aggiunto LED di stato SafetyMonitor nella Status Bar prima del led di Stato dell’Application Server (spento=non configurato, rosso = No Safe, verde = Safe)
NEW => Il paradigma di connessione/disconnessione è stato cambiato è ora possibile effettuare connessioni/disconnissione di singoli controlli [in questa daily build solo il SafetyMonitor]
NEW => Le sezioni di Voyager sono ora sempre operative anche senza aver connesso il setup
NEW => Aggiunto blocco nel DragScript per connettere il solo controllo SafetyMonitor. Utile per monitorare le condizioni favorevoli prima di connettere tutto il setup se si usa il solo safety monitor
NEW => Le Sequenze sono ora associate al Profilo di Setup caricato
NEW => Grazie all’associazione al profilo le Sequenze possono essere create/modificate anche senza essere connessi al setup
NEW => Esiste uno strumento automatico di selezione del profilo delle Sequenze da utilizzar per il loro editing (Automatico al profilo attuale, lasciando il profilo originale, selezionando manualmente il profilo)
NEW => Grazie allo strumento automatico di selezione del profilo Sequenze è possibile da un profilo editare anche sequenza di altro profilo senza caricarlo
NEW => Aggiunto al menù Tools anche l’Editor Sequence, le Sequence possono essere gestite anche durante l’esecuzioni di Azioni
NEW => Quanto fatto per le Sequenze in merito al Profilo è applicabile anche alle Sequenze di Ricerca & Survey
NEW => Le Sequenze Flat sono ora associate al Profilo di Setup caricato
NEW => Grazie all’associazione al profilo le Sequenze Flat possono essere create/modificate anche senza essere connessi al setup
NEW => Esiste uno strumento automatico di selezione del profilo delle Sequenze Flat da utilizzar per il loro editing (Automatico al profilo attuale, lasciando il profilo originale, selezionando manualmente il profilo)
NEW => Grazie allo strumento automatico di selezione del profilo Sequenze Flat è possibile da un profilo editare anche sequenza flat di altro profilo senza caricarlo
NEW => Aggiunto al menù Tools anche l’Editor Flat Sequence, le Flat Sequence possono essere gestite anche durante l’esecuzioni di Azioni
NEW => Aggiunto nuovo blocco per il dithering non guidato nel DragScript
NEW => Aggiunto Application Server anche al resto delle versioni commerciali di Voyager, attivabile da Setup al tab Voyager Box Application Server
NEW => Aggiunto Evento NewFITReady per la realizzazione da parte di alcuni utenti di FITViewer ed Data Analyzer personalizzati
MOD => Aggiunto Int16 come tipo dato ammesso negli header FIT per la lunghezza focale. In PlateSolve2 la risoluzione del FIT falliva se il file era salvato con un particolare programma di automazione esterno
MOD => Il blocco external script è stato esteso per opzionalmente salvare il testo di ritorno STDOUT in un Decimal DragSCript
MOD => Il blocco di Dragscript per il puntamento AltAz può ora simulare forzatamente il puntamento richiesto trasformando in RA e DEC la posizione indicata
MOD => Aggiunto parsing evento Calibrating nel protocollo di comunicazione con PHD2
MOD => Aggiunte domande di conferma per la getione degli script modificati e non salvati durante il rest, il caricamento e la chiusura dell’Editor
MOD => Aggiunto Flag nel Blocco Unguided Dithering per utilizzare la posizione attuale in caso di valore di posizione originario vuoto
BUG => Errata Gestione del Time Start e Time End per alcuni intervalli di tempo , ricreata da zero gestione del timing
BUG => Errata segnalazione di Contatore/Stringa non ancora definito nei blocchi di gestione Variabili del DragScript
BUG => la modalitĂ Dome veniva resettata se scelto Ascom Dome o Ascom Dome ConnectionLess
BUG => Le informazioni relative ai controlli configurati venivano erroneamente rimosse se i controlli erano connessi e si effettuavano cambi sul setup di Voyager
