[FLATDEVICE] => NEW => Aggiunto nuovo controllo flat device ARTESKY Flat Box
[VIEWER - TOOLBAR] => NEW => Aggiunto comando HQ in toolbar per attivare / disattivare Alta qualitĂ disegno senza entrare nei settaggi
[FLAT] => NEW => Aggiunto tempo di ritardo dopo modifica luminositĂ flat device se la luminositĂ viene ridotta
[VIEWER - STATISTICS] => BUG => Sostituita DLL Math, poteva verificarsi un errore nel calcolo della media immagine
[FLATDEVICE] => NEW => Added new ARTESKY Flat Box flat device control
[VIEWER - TOOLBAR] => NEW => Added HQ command in toolbar to enable / disable High quality design without entering the settings
[FLAT] => NEW => Added delay time after changing brightness flat device if the brightness is reduced
[VIEWER - STATISTICS] => BUG => Replaced Math DLL, an error could occur in the calculation of the mean value of image
https://www.telescopi-artesky.it/en/artesky/flat-field-panels/3586-flat-box-usb-250mm-artesky.html
