In this version:
NEW => Added possibility to set a wait delay after an increase in brightness of the flat device during the action of AutoFlat to stabilize the panel light
NEW => Custom Array -> Added SIMBAD Search to the Remote Sequence configurator
MOD => Improved management of camera sensor size get in TheSkyX
BUG => in case of plate abort and ASTAP blind solving, an error message was generated in the monitor and in the log that was not understandable
BUG => A generic error was generated in the RoboClip management form in the event of an empty list and cancellation of the insertion of a new target
BUG => In the DragScript editor, searching the RoboClip via Voyager sometimes generated a generic “Find Error”
BUG => In RoboSync in case of offset applications azimuth values ​​<0 ° or> = 360 ° could be verified
BUG => DragScript -> In the simulator the Repeat Until End Civil / Nautical / Astronomical Night was not correctly handled, generating an exception
BUG => The AutoFlat action checked the presence and connection of the Flat Device even if not necessary, generating an abort of the action
BUG => Custom Array -> In case of selection of customized sequence directories in the general settings of Voyager [PATH] of the various Nodes, the files were in any case saved in the default directory
In questa versione:
NEW => Aggiunta possibilità di impostare un ritardo di attesa dopo un incremento di luminosità del flat device durante l’azione di AutoFlat per stabilizzare la luce del pannello
NEW => Custom Array -> Aggiunta Ricerca SIMBAD al configuratore di Sequenze Remote
MOD => Migliorata gestione recupero dimensioni sensore camera in TheSkyX
BUG => in caso di abort del plate e blind solving di ASTAP veniva generato un messaggio di errore nel monitor e nel log non comprensibile
BUG => Nel form di gestione del RoboClip veniva generato un errore generico in caso di lista vuota e cancellazione dell’operazione di inserimento di un nuovo target
BUG => Nell’editor del DragScript, la ricerca tramite Voyager del RoboClip in alcune occasioni generava un errore generico “Find Error”
BUG => Nel RoboSync in caso di applicazioni di offset si potevano verificare valori di azimuth <0° o >=360°
BUG => DragScript -> Nel simulatore non veniva correttamente gestito il Repeat Until End Civil/Nautical/Astronomical Night generando un’eccezione
BUG => L’azione di AutoFlat verificava la presenza e la connessione del Flat Device anche se non necessario generando un abort dell’azione
BUG => Custom Array -> In caso di selezione di directory di sequenza personalizzate nei settaggi generali di Voyager [PATH] dei vari Nodi i file venivano comunque salvati nella directory di default
Click here for manual download:
