A new version of Voyager is ready to download in automatic or manual mode!
Voyager 2.2.7 - Build 2020-03-16
In this version:
NEW => In the DragScript editor inserted new script among the preloaded for continuous exposure in loop
NEW => In the FITViewer settings it is now possible to select the type of viewfinder: circular target or crossed lines
NEW => New Wait User OK block inserted to receive manual OK from user to continue, with optional Timeout management
NEW => New Operating System Hibernation Block added in DragScript
NEW => New Operating System Suspension Block added in DragScript
NEW => Added FITViewer launcher icon to Desktop during Voyager installation
NEW => In the configuration of the DragScript block related to the Sequence for Custom Array the same timing management has been added as the normal Sequence
NEW => In the configuration of the DragScript block related to the Sequence, the override management of the min and max HourAngle has been added
NEW => Override management of the min and max HourAngle has been added in the configuration of the DragScript block relating to the Sequence for Custom Array
NEW => Override management of the min and max Altitude has been added in the configuration of the DragScript block relating to the Sequence for Custom Array
NEW => Added parameter to force the meridian change with maximum time limit in the sequence for Custom Array
NEW => Added dedicated icon on tools menu to modify the sequence of the Custom Array even during the running of the actions and the status of the disconnected array
MOD => Strengthened code that moves the information on the status bar of the main Voyager window
MOD => Strengthened code that starts the FITViewer from the Voyager menus
MOD => [DASHBOARD] Overlap percent is now calculated on the longest side of your FoV and used equally on both sides.
MOD => [DASHBOARD] Default overlap settings is now 15%, you can still set from 0 to 40%
MOD => [DASHBOARD] Canvas Line tracing notation improved for iOS compatibilty
MOD => [DASHBOARD] Dropdown profile selection is now forced to bottom direction to avoid going under the FoV canvas.
BUG => It was not possible to select files with the .fits extension for plate solving of referenced FIT files from OnTheFly
BUG => The calculation of the Altitude for the execution constraints of the Sequence was made on the wrong format (J2000) instead of on the format (JNow)
BUG => The calculation of the Dome synchronization data in RoboSync was performed on the wrong format (J2000) instead of on the format (JNow)
BUG => Wrong copy and paste of the DO IF HA BETWEEN block in the DragScript editor
BUG => [DASHBOARD] Corrected counterclockwise rotation of PA. IMPORTANT: this make it necessary to redo the Framing or Mosaic saved on RoboClip from Virtual FoV, but ONLY if you have used PA unequal to 0. Sorry for this drawback.
[ITA]
In questa versione:
NEW => Nell’editor di DragScript inserito nuovo script tra i precaricati per l’esposizione continua in loop
NEW => Nei settaggi del FITViewer è ora possibile selezionare la tipologia di mirino: target circolare o linee incrociate
NEW => Inserito nuovo Blocco Wait User OK per ricevere OK manuale da utente per proseguire con opzionale gestione del Timeout
NEW => Inserito nuovo Blocco Ibernazione Sistema Operativo
NEW => Inserito nuovo Blocco Sospensione Sistema Operativo
NEW => Aggiunta icona di avvio FITViewer al Desktop durante installazione Voyager
NEW => Nella configurazione del blocco di DragScript relativo alla Sequenza per Custom Array è stato aggiunta la stessa gestione timing della normale Sequenza
NEW => Nella configurazione del blocco di DragScript relativo alla Sequenza è stata aggiunta la gestione in override del min e max HourAngle
NEW => Nella configurazione del blocco di DragScript relativo alla Sequenza per Custom Array è stato aggiunta la gestione in override del min e max HourAngle
NEW => Nella configurazione del blocco di DragScript relativo alla Sequenza per Custom Array è stato aggiunta la gestione in override della min e max Altitudine
NEW => Aggiunto parametro per forzare il cambio meridiano con limite massimo di tempo nella Sequenza per Custom Array
NEW => Aggiunta icona dedicata su menù tools per modificare la sequenza del Custom Array anche durante il running dell’azioni e lo stato di array disconnesso
MOD => Irrobustito codice che movimenta le informazioni sulla status bar della finestra principale di Voyager
MOD => Irrobustito codice che avvia il FITViewer dai menĂą di Voyager
MOD => [DASHBOARD] La percentuale di sovrapposizione viene ora calcolata sul lato piĂą lungo del FoV e utilizzata allo stesso modo su entrambi i lati.
MOD => [DASHBOARD] Le impostazioni di sovrapposizione predefinite ora sono del 15%, è comunque possibile impostare da 0 a 40%
MOD => [DASHBOARD] Notazione di traccia di Canvas Line migliorata per compatibilitĂ iOS
MOD => [DASHBOARD] La selezione del profilo a discesa è ora forzata nella direzione inferiore per evitare di passare sotto il livello FoV.
BUG => Non era possibile selezionare i file con estensione .fits per il plate solving di referenced FIT file da OnTheFly
BUG => Errato copia ed incolla del blocco DO IF HA BETWEEN nell’editor di DragScript
BUG => Il calcolo dell’Altitudine per i vincoli di esecuzione della Sequenza veniva effettuato sul formato sbagliato (J2000) invece che sul formato (JNow)
BUG => Il calcolo dei dati di sincronizzazione del Dome in RoboSync veniva effettuato sul formato sbagliato (J2000) invece che sul formato (JNow)
BUG => [DASHBOARD] Rotazione PA corretta in modalità antioraria. IMPORTANTE: questo rende necessario ripetere l’inquadratura o il mosaico salvati su RoboClip da Virtual FoV, ma SOLO se hai usato una PA diversa da 0. Ci scusiamo per questo inconveniente
