MANUAL DOWNLOAD LINK:
https://www.dropbox.com/s/jxx61gw6rfrc2sn/Voyager_Setup_2.3.0.zip?dl=1
Release 2.3.0 - Built 2021-01-21 - INFO
⦁ Voyager moved to release 2.3.0. A new management of the internal SDK drivers and some changes to the graphic interface engine and to the profile management have been introduced to make room for new features. Also the Online Update service has been changed, now an installation package will be downloaded directly as for the normal Download. For this reason, the download of the new release 2.3.0 of Voyager is not automatic but by your direct will. To update you need to download the installation from the official Voyager website:https://software.starkeeper.it/#download_voyager_section
⦁ It is recommended to make a copy of the Voyager profiles folder, found under Documents in the Voyager folder. The folder to be copied is called Profile
⦁ The new installation will overwrite the previous one unless you used a different folder during a manual or compressed file installation. However, you can go back by downloading an old installation from the Official site. Profiles and all data are compatible with release 2.2.x and earlier
⦁ The Update button will not update the release but it will cause an error if you use it, do not use it
⦁ Once Voyager Release 2.3.0 has been installed, the automatic download service will automatically be active.
⦁ For any help or clarification, do not hesitate to contact assistance in the manner indicated in the license email
IN THIS VERSION:
[New] Added pattern for File Naming $$ SEQSLOTNUM $$, indicates the slot number of the sequence shot
[New] Added pattern for File Naming $$ SEQSLOTREPEATNUM $$, indicates the repetition index of the click inherent in the Sequence slot
[New] Added pattern for File Naming $$ SEQOVERALLFRAMENUM $$, indicates the absolute progressive number of clicks in the sequence
[New] Array -> It is now possible to manage nodes with authentication in the Array
[New] Added new native camera control for FLI CCD cameras
[New] Added new native filter wheel control for FLI filter wheels
[New] All the DLLs related to the various SDKs used by Voyager are now contained in a dedicated folder called platform to avoid possible conflicts with the use in sharing with other applications / libraries
[New] FITViewer -> The possibility of putting the window in always on top mode has been added to the settings
[New] Application Server -> Added management of Set OUT, DAC, AUTOMA, PWM commands
[New] Added new ASCOM Cover Calibrator Flat Device control, version 6.5 or later of the ASCOM platform must be installed
[New] New ASI V2 Camera control added, native driver updated to manage cameras with ROI in FPGA (ASI294MM Pro), the driver uses the latest SDK released by ZWO ASI and needs the V3.16 camera driver from 2020.12.30 and later
[New] For compatibility with ASI cameras and with the management mode used up to SDK 1.16.0 by the native Voyager driver, the camera control has been left selectable, it has its SDK 1.16.0 reserved in the platform structure of the installation (platform \ ASI \ V1)
[New] Added second Viking client for second Viking instance control (Viking version 1.0.24 or later required)
[New] Added to Voyager the auto backup of the current profile folder in a dedicated ProfileBackup folder, the saving takes place automatically at start-up and before the online update with folder indicating the complete save date. It is possible to indicate the maximum age of the backups in Configuration-> Tab Voyager. Voyager will also remove the older ones
[New] DragScript -> Added new NODE EXECUTE DRAGSCRIPT block to start the execution of a remote dragscript for the SLAVE NODES of an ARRAY
[New] The PHD2 Client JSON-RPC command execution timeout time is now configurable. Setting in setup-> Guiding-> PHD2 Process
[New] Array -> The ability to perform operations on Local and Remote Flat devices has been added to the Nodes Utility
[New] Added QHY CMOS BETA Camera control for using the Beta SDK drivers, the drivers are in the reserved space in the installation platform structure (platform \ QHY \ BETA)
[Mod] The online Voyager update management system has changed, now the installer is downloaded and started directly
[Mod] The list of controls available for each individual Setup component now appears in the configuration lists in alphabetical order
[Mod] Array -> Empty array node names are not acceptable
[Mod] Strengthened management code for the frame tracking during SKYFLAT and the restore of the initial tracking condition of the frame at the end of SKYFLAT
[Mod] Strengthened Viking Client Management
[Mod] In case of multiple EXIT or SUSPEND events, the event is now generated at the expiry of the shortest integration between the various active sources
[Mod] The QHY Beta SDKs require the removal of the ReleaseQHYCCDResource call of the SDK, otherwise the need to close and reopen Voyager after disconnecting the camera. We have asked QHY for clarification regarding the lack of information on this change to avoid future disruptions to Voyager users
[Bug] Attempts to bring the Sky PA to the value indicated in the case of plate solving of the mount position outside the allowed error limit were incorrectly counted, this could lead to the abortion of the Sequence
[Bug] Application Server -> Webdashboard parsing error in case of sending data with infinite value in the NewJPGReady event
[Bug] Negative angles are not saved in the Camera PA field of the Voyager settings profile, before the transition is made in range 0-360
[ITA]
LEGGERE PRIMA DI AGGIORNARE - UPDATE SOLO MANUALE
⦁ Voyager è passato alla release 2.3.0. Una nuova gestione dei driver SDK interni ed alcuni cambiamenti al motore dell’interfaccia grafica ed alla gestione dei profili sono stati introdotti per dare spazio a nuove funzionalità. Il servizio di Update online è stato cambaito, ora verrà scaricato direttamente un pacchetto d’installazione come per il normale Download. Per questo motivo il download della nuova release 2 di Voyager non è automatico ma per vostra volontà diretta. Per effettuare l’aggiornamento occorre scaricare l’installazione dal sito ufficiale di Voyager: https://software.starkeeper.it/#download_voyager_section
⦁ Si consiglia di effettuare una copia della cartella profili di Voyager , la trovate sotto Documenti nella cartella Voyager. La cartella da copiare si chiama Profile
⦁ La nuova installazione sovrascriverà la precedente a meno che non abbiate usato una cartella diversa durante una installazione manuale o da file compresso. Potrete comunque tornare indietro scaricando una vecchia installazione dal sito Ufficiale. I profili e tutti i dati sono compatibili con la release 2.2.x e precedenti
⦁ Il tasto di Update non aggiornerà la Release ma vi genererà un errore se lo userete, non usatelo
⦁ Una volta effettuata l’installazione della Release 2.3.0 di Voyager, il servizio di download automatici sarà automaticamente attivo.
⦁ Per ogni aiuto o chiarimento non esitate a contattare l’assistenza nelle modalità riportate nella mail di licenza
ELENCO DELLE NOVITA’ IN QUESTA VERSIONE
[New] Aggiunto pattern per File Naming $$SEQSLOTNUM$$ , indica il numero di slot dello scatto della Sequenza
[New] Aggiunto pattern per File Naming $$SEQSLOTREPEATNUM$$ , indica l’indice di ripetizione dello scatto inerente lo slot di Sequenza
[New] Aggiunto pattern per File Naming $$SEQOVERALLFRAMENUM$$ , indica il numero assoluto progressivo di scatto nella sequenza
[New] Array -> E’ ora possibile gestire negli Array nodi con autenticazione
[New] Aggiunto nuovo controllo camera nativo per le Camere FLI CCD
[New] Aggiunto nuovo controllo ruota portafiltri nativo per le Ruote portafiltri FLI
[New] Tutte le DLL relative ai vari SDK utilizzati da Voyager sono ora contenuti in una cartella dedicata chiamata platform per evitare possibili conflitti con l’utilizzo in sharing con altre applicazioni/librerie
[New] FITViewer -> Aggiunta ai settaggi la possibilità di mettere la finestra in modalità always on top
[New] Application Server -> Aggiunta gestione comandi di Set OUT,DAC,AUTOMA,PWM
[New] Aggiunto nuovo controllo Flat Device del tipo ASCOM Cover Calibrator , necessario aver installata la versione 6.5 o successiove della piattaforma ASCOM
[New] Aggiunto nuovo controllo Camera ASI V2, driver nativo aggiornato per gestire le camere con ROI in FPGA (ASI294MM Pro), il driver utilizza l’ultimo SDK rilasciato da ZWO ASI e necessita del driver della camera V3.16 del 2020.12.30 e successivi
[New] Per compatibilità con le camere ASI e con la modalità di gestione utilizzata sino all’SDK 1.16.0 dal driver nativo di Voyager, il controllo camera è stato lasciato selezionabile, ha il suo SDK 1.16.0 riservato nella struttura platform dell’installazione (platform\ASI\V1)
[New] Aggiunto secondo client di Viking per controllo seconda instanza di Viking (necessario Viking con versione 1.0.24 o successive)
[New] Aggiunto a Voyager l’auto backup della cartella dei profili attuale in una cartella ProfileBackup dedicata, il salvataggio avviene automaticamente all’avvio e prima dell’update online con cartella indicante data completa di salvataggio. E’ possibile indicare in Configurazione->Tab Voyager l’eta massima dei backup. Voyager provvederà anche a rimuovere i più vecchi
[New] DragScript -> Inserito nuovo blocco NODE EXECUTE DRAGSCRIPT per avviare l’esecuzione di un dragscript remoto per i NODI SLAVE di un ARRAY
[New] Il tempo di timeout esecuzione comandi JSON-RPC del Client PHD2 è ora configurabile. Impostazione in setup->Guiding->PHD2 Process
[New] Array -> Aggiunto in Utility dei Nodi la possibilità di eseguire operazioni sui Flat device Locali e Remoti
[New] Aggiunto controllo Camera QHY CMOS BETA per l’utilizzo dei driver Beta di SDK, i driver sono nella spazio riservato nella struttura platform dell’installazione (platform\QHY\BETA)
[Mod] Il sistema di gestione degli update di Voyager online è cambiato, ora viene scaricato ed avviato direttamente l’installer
[Mod] L’elenco dei controlli disponibili per ogni singolo componente del Setup appare ora negli elenchi di configurazione in ordine alfabetico
[Mod] Array -> Non sono accettabili nomi dei nodi dell’array vuoti
[Mod] Irrobustito codice di gestione del tracking montatura durante gli SKYFLAT ed il restore della condizione iniziale di tracking della montatura a fine SKYFLAT
[Mod] Irrobustita gestione Client Viking
[Mod] In caso di eventi multipli di EXIT o SUSPEND viene ora generato l’evento allo scadere dell’integrazione più corta tra le varie fonti attive
[Mod] Gli SDK Beta della QHY obbligano alla rimozione della chiamata ReleaseQHYCCDResource dell’SDK pena la necessita dopo la disconnessione della camera di dover chiudere e riaprire Voyager. Abbiamo richiesto delucidazioni alla QHY in merito alla mancata informazione su tale modifica per evitare disservizi futuri agli utenti di Voyager
[Bug] Veniva conteggiati erroneamente i tentativi di portare la Sky PA al valore indicato nel caso di plate solving della posizione montatura fuori dal limite d’errore consentito, questa poteva portare all’abort della Sequenza
[Bug] Application Server -> Errore di parsing da parte della webdashboard in caso di invio dati con valore infinito nel’evento NewJPGReady
[Bug] Non vengono salvati angoli negativi nel campo Camera PA del profilo settaggi di Voyager, prima viene effettuata transizione in range 0-360
