Automatic or with Manual Download at this direct link [32 bit]:
https://www.starkeeper.it/voyager/Voyager_Setup_2.3.10.zip
Automatic or with Manual Download at this direct link [64 bit]:
https://www.starkeeper.it/voyager/Voyager_Setup_2.3.10_64bit.zip
Release 2.3.10 - Built 2023-11-19 - UPDATE INFO
NEW => Sequence → Added GUIDMETH as a string header in the saved FIT indicating the guidance method used (none or UNDEF = no guidance, PHD2, DONUTS, MAXIMDL, THESKYX, THESKY64)
NEW => RoboTarget → The minimum time between one call and the next to the Scheduler (previously 60 seconds) is now configurable in the action parameters both from the RoboTarget window and from the RoboTarget DragScript block. It is strongly recommended to leave the default
NEW => Player One Camera → Added new Camera type for direct support of Player One Astronomy Cameras. The firmware and drivers of these cameras are truly high level and allow you to change the readout mode during the sequence without reinitializing the camera itself (as is necessary to do for example for QHY cameras). Then proceed to recover the ReadoutModes with the camera disconnected during the first configuration. Release will follow which will unlock the function in RoboTarget Manager
NEW => Application Server → DEBUG flag introduced to remove mandatory polling DEBUG_DisablePolling
NEW => Sequence → Added new override to change the final autofocus position of an Offset Steps (only for those using RoboFire). Useful for Astrometry or zonal problems
NEW => RoboTarget Manager → Added possibility to override the final autofocus point with an Offset Steps, valid only for those who use the RoboFire as a focus control
BUG => DragScript → In the Kill Process block the TheSky64 process name was incorrect
BUG => GeoData Cache → The cache was invalidated when verifying the use of the Virtual mount, making the search for asteroid and comet orbits unavailable when the mount was disconnected
BUG => Player One Camera → The exposure type flag was not set correctly when starting the exposure, dark and bias were created with the electronic shutter open
BUG => Wrong Focus Stars → Star data access was not ported to 64 bit by mistake, the wrong focus stars system was not accessible
BUG => Application Server → ControlData Event after Autofocus disconnected report always AFCONN=True
BUG => RoboTarget Manager → In the Shot editor the Bin0 which does not exist was incorrectly accepted, generating an exposure execution error in some camera drivers
BUG => RoboTarget only Dynamic targets → If a previously existing comet or asteroid is not found in the Dynamic Target database, RoboTarget continues to give an error by exiting the action and without suspending the non-existent target
