Voyager 2.3.12 Release - Built 2025-02-16 (32bit and 64bit)
Automatic or with Manual Download at this direct link [32 bit]:
https://www.starkeeper.it/voyager/Voyager_Setup_2.3.12.zip
Automatic or with Manual Download at this direct link [64 bit]:
https://www.starkeeper.it/voyager/Voyager_Setup_2.3.12_64bit.zip
Release 2.3.12 - Built 2025-02-16 - UPDATE INFO
NEW => OnTheFly → Search Target → Added dynamic target of type PLANETS and related button with dynamic search form
NEW => OnTheFly → Search Target → Added dynamic target of type DYNASEARCH to retrieve coordinates directly from the planetarium with the selected text
NEW => DragScript → The GOTO DYNAMIC TARGET block is now able to handle also dynamic targets of type PLANET
NEW => DragScript → The PRECISE POINTING DYNAMIC TARGET block is now able to handle also dynamic targets of type PLANET
NEW => DragScript → The SEQUENCE block is now able to handle also dynamic targets of type PLANET and DYNASEARCH
NEW => Sequence → The Sequence can now use as dynamic targets also the Planets
NEW => Sequence → The Sequence can now use as dynamic targets also objects of the Planetarium control (such as the moons of the planets for example) called DynaSearch if connected to Voyager, the exact string entered will be searched for coordinates retrieval
NEW => Robotarget → RoboTarget is now able to use Planets
NEW => Robotarget → RoboTarget is now able to use Planetarium control objects (such as planet moons for example) called DynaSearch if connected to Voyager, the exact string typed will be searched for coordinates retrieval
NEW => RoboTarget Manager → Implemented management of Dynamic Targets of the Planets type
NEW => RoboTarget Manager → Implemented management of Dynamic Targets of the DynaSearch type, i.e. objects of the Planetarium control (such as planet moons for example) called DynaSearch if connected to Voyager, the exact string typed will be searched for coordinates retrieval
NEW => Voyager NDA → Changed APIs to manage Dynamic Targets of the Planets and DynaSearch type
NEW => DragScript → The DO IF ALTITUDE DYNAMIC TARGET block is now able to also manage targets PLANET type dynamic targets
NEW => DragScript → The DO IF ALTITUDE BETWEEN DYNAMIC TARGET block is now able to handle also PLANET type dynamic targets
NEW => DragScript → The DO IF AZIMUTH BETWEEN DYNAMIC TARGET block is now able to handle also PLANET type dynamic targets
NEW => DragScript → The DO IF HA BETWEEN DYNAMIC TARGET block is now able to handle also PLANET type dynamic targets
NEW => RoboTarget Manager → Added the possibility to indicate negative Gain for CMOS cameras
NEW => ATTENTION !! Updated ASI Camera V2 SDK to version 1.36.0.0 of 2024.08.12 , MANDATORY Install the latest ASI Camera drivers to support this SDK - Then check the Remove Overscan Area settings if used
NEW => DragScript → Added new Conditional block DO IF MOON PHASE to decide to do operations based on the moon phase (Only for users with Voyager Advanced/Full license)
NEW => ATTENTION !! Updated QHY Beta Camera SDK to version 24.12.26.12 of 2024.12.26 , MANDATORY Install the latest QHY Camera drivers (All in One) to support this SDK - Then check the Remove Overscan Area settings if you use
NEW => Application Server → Added new RemoteGetListAvalaibleSequenceEx method to have a list of available sequences also based on the indicated Voyager profile
NEW => Application Server → Added new RemoteGetSequenceConfiguration method to retrieve the configuration of a Sequence in JSON format (available for Advanced, Full License or for Developer plugin)
NEW => Application Server → Added new RemoteSetSequenceConfiguration method to modify the configuration of a sequence or create a new one (available for Advanced, Full License or for Developer plugin)
NEW => SkyFlat & Flat → It is now possible to decide whether to activate the settling time of the mount after the goto (time for the oscillation damping) or use the default setting which is to not wait
MOD => Windows UI Manager → Updated to DeveExpress version 16.2
MOD => FIT HEADERS → Adjusted OBJCTxxx to the standard SBFITSEXT 1.0 rules for compatibility with the latest versions of CCDInspector
MOD => DragScript Editor → Default default alphabetical sorting of available blocks
MOD => QHY SDK → Increased the maximum number of read modes that Voyager can handle for the latest SDK versions (August 2024 onwards) as indicated by QHY developers for model 600 cameras, an index out of range error was highlighted during configuration
BUG => RoboOrbits → For asteroids, ephemeris calculations were incorrect for particular objects with an inclination greater than 100° (no need to re-import orbital data)
Wow, that’s a big release. Thanks, Leo.
Thanks Glenn
Thank you Leo. Looks like a lot of support for dynamic targets such as planets is added. Is there a way to record .avi or .ser movies, rather than single exposures?
Absolutely not, Voyager was not born to do this.
I was wondering this myself. There must be something that can tie to Voyager and do that (like when we use The Sky X or other program). I would like to capture planets autonomously. Have you found a solution?
