Manual Download direct link:
https://www.starkeeper.it/voyager/Voyager_Setup_2.3.2.zip
Dropbox link:
https://www.dropbox.com/s/16i8j9l90j99dl2/Voyager_Setup_2.3.2.zip?dl=1
Release 2.3.2 - Built 2021-04-22 - UPDATE INFO
NEW => Autofocus → Added possibility to use Observing Conditions as temperature trigger (TEMPERATURE parameter). Option available in Setup-> Autofocus-> Focus Trigger box
NEW => RoboFire → Added option to activate a delay after each focuser movement. Option available in focuser tab of RoboFire Focuser configuration
NEW => Sequence → Added possibility to execute external scripts before and after the meridian change operation
NEW => Mount → Added possibility to override the mount position (Latitude and Longitude) without reading it from the driver. Option in Setup-> Mount-> Latitude / Longitude Position Override box
NEW => DragScript → A new block UPDATE DECIMAL FROM ROTATOR PA has been added to assume the PA of the rotator coming from the Driver in a decimal variable
NEW => RoboFire → Added advanced parameter to manage the progression of the focuser during the realization of the first slope of the VCurve. You can lower the resolution of the progression if you receive an error during the first light due to the few points found for the calculation of the first slope. The setting is found in the RoboFire Configuration form on the VCurve tab
NEW => DragScript → New Serial TX Block added To send binary data to the serial port
NEW => DragScript → New SEND TELEGRAM block added to send messages via Telegram Chatbot (you must be registered and have ChatID and API ID)
NEW => FIT → Added optional parameter in configuration (Setup-> Camera-> Various) to remove personal data from FIT Headers (SITELAT, SITELONG, OWNER, SWOWNER, OBSERVER)
NEW => FITVIewer → Added optional parameter in the settings to save the STF stretch in JPG format of the last FIT opened automatically by the Viewer. You can select the folder in which to save the JPG. The fixed name is LastSTFAutoOpenImage.jpg
NEW => The new device just released by GEOPTIK USB Flat device Control has been added to the FLAT DEVICES
NEW => Renting → Added ActivationCode management as login to the dashboard. Necessary plugin renting and renting service enabled in Voyager
NEW => TheSky64 → Added control management of the new 64-bit TheSkyX from Software Bisque
NEW => TheSkyX / 64 → Added AO management in camera control
NEW => FilePattern → Added $$ SETTEMP $$ pattern (reports required temperature in sequence as two-digit unsigned integer)
NEW => FilePattern → Added $$ YY08 $$ pattern (returns year with the same logic as the $$ VOYDATEFOLDER08 $$ pattern)
NEW => FilePattern → Added $$ MM08 $$ pattern (returns month with same logic as $$ VOYDATEFOLDER08 $$ pattern)
NEW => FilePattern → Added $$ DD08 $$ pattern (reports day with same logic as $$ VOYDATEFOLDER08 $$ pattern)
NEW => Tools → A new tool has been introduced in OnTheFly to help manually rotate the camera to the desired Sky PA
NEW => Tools → Added adjustment field in module 90/180 ° in the tool to help in the manual rotation of the camera to the desired Sky PA
NEW => ASI Camera → Voyager Driver for ASI V2 cameras updated to SDK version 1.17.0 of 2021.03.24, it is recommended to install at least the camera drivers V3.16 of 2020.12.30
NEW => QHY Camera → Updated Voyager Driver for QHY Beta cameras to SDK version 2.3.13 of 2021.03.13
NEW => Tools → Introduced double scale for the inverted mode in the tool to assist in the manual rotation of the camera to the desired Sky PA
NEW => PHD2 → Introduced OPTIONAL PHD2 Profile change management, it is now possible to associate a PHD2 profile to the Voyager profile so that it automatically switches when the setup is connected. Profiles can be retrieved from Voyager Setup, Guiding tab, PHD2 Profile Selection
NEW => DragScript → New Change Voyager Profile Block added
NEW => DragScript → Added state of enabling the Emergency Events (Exit, Suspend, Light) in the window of the DragScript section
NEW => DragScript → Added new command line parameter / rundefault to start a dragscript indicating only the file name. It will be searched and executed from the default script directory used by Voyager
NEW => Sequence → Added Flag to activate the recalibration of the guide every X minutes in the Guide-Dithering tab of the Sequence configurator. Useful for those with fork mount and active derotation system. The guide recalibration is only performed if the Sequence also manages the initial guide calibration
NEW => Sequence → Added Flag to activate the check required for each Realign target of the rotator tolerance. Useful for those with fork mount and active derotation system
NEW => Weather → The possible deactivation of the LIGHT Conditions is highlighted in the Weather status widget, in case of deactivation of the LIGHT Conditions the SAFE status is also shown in brackets considering the LIGHT Conditions
MOD => DragScript → Sending Mail via Voyager account, updated the TLS protocol to 1.2 as the service provider will soon not accept lower levels
MOD => DragScript → Added possibility to indicate decimal variable as Rotator rotation value
MOD => FIT → Changed the NULL character of the Header Unit to adhere to the FIT standard (Error loading in AstroPixelProcessor)
MOD => DragScript → During the execution of the Repeat Block for N Times the current repetition number is now highlighted together with the total number of repetitions requested
MOD => Changed the connection method to the socket of the Voyager Application Server to asynchronous to avoid dead lock of the FITViewer connections in case of absence of Voyager
MOD => TheSkyX / 64 → Changed AO homing method
MOD => DragScript → Made mandatory selection of ENABLED / DISABLED Events in case of DragScript start from Custom Block
MOD => Wait Safe → The Wait Safe action has been adapted to the new management of LIGHT Conditions introduced with this version
MOD => Distributed Safe → The Distributed Safe action has been adapted to the new management of LIGHT Conditions introduced with this version
BUG => Array → If the array element was disabled, the synoptic of the sequential exposures of node 3 was not displayed
BUG => Array → In case of disabled array element some functions of Utility tab and Nodes tab failed or executed commands on wrong Nodes
BUG => Array → If the array element is disabled or disconnected, the sequence could fail or generate unwanted warnings and errors
BUG => SkyFlat → The Flat Altitude parameter was not used in the general SkyFlat settings. In any case, it is strongly recommended not to modify it and leave it at the default value of 75 °
BUG => DragScript → In some conditions the automatic restart of the Dragscript from the internal blocks did not reset the override conditions of the previous boot if they existed, leading to malfunctions
BUG => DragScript → In some conditions Even if the management of the LIGHT conditions in the weather was disabled, it was still used for the final calculation of the SAFE status
[ITA]
NEW => Autofocus → Aggiunta possibilità di utilizzare come trigger di temperatura le Observing Conditions (Parametro TEMPERATURE). Opzione disponibile in Setup->Autofocus->Focus Trigger box
NEW => RoboFire → Aggiunta opzione per attivare un ritardo dopo ogni movimente del focheggiatore. Opzione disponibile nel tab focuser della configurazione Focuser di RoboFire
NEW => Sequence → Aggiunta possibilità di eseguire script esterni prima e dopo l’operazione di cambio meridiano
NEW => Mount → Inserita possibilità di eseguire Override della posizione della montatura (Latitudine e Longitudine) senza leggerla dal driver. Opzione in Setup->Mount->Latitude / Longitude Position Override box
NEW => DragScript → Inserito nuovo blocco UPDATE DECIMAL FROM ROTATOR PA per assumere in una variabile decimale la PA del rotatore proveniente dal Driver
NEW => RoboFire → Aggiunto parametro avanzato per la gestione della progressione del focheggiatore durante la realizzazione della prima Slope della VCurve. Si può abbassare la risoluzione della progressione se si riceve errore durante la first light a causa dei pochi punti trovati per il calcolo della prima Slope. Il settaggio si trova nel form di Configurazione del RoboFire al tab VCurve
NEW => DragScript → Inserito nuovo Blocco Serial TX Per inviare dati binari alla porta seriale
NEW => DragScript → Inserito nuovo Blocco SEND TELEGRAM per inviare messaggi tramite Chatbot di Telegram (occorre essere iscritti ed avere ChatID e API ID)
NEW => FIT → Aggiunto Parametro opzionale in configurazione (Setup->Camera->Various) per rimuovere i dati personali dagli Header FIT (SITELAT, SITELONG,OWNER,SWOWNER,OBSERVER)
NEW => FITVIewer → Aggiunto parametro opzionale nei setting per salvare lo stretch STF in formato JPG dell’ultimo FIT aperto in automatico dal Viewer. Si può selezionare la cartella in cui salvare il JPG. Il nome fisso è LastSTFAutoOpenImage.jpg
NEW => Aggiunto ai FLAT DEVICE il nuovo dispositivo appena rilasciato dalla GEOPTIK USB Flat device Control
NEW => Renting → Aggiunta gestione ActivationCode come login alla dashboard. Necessaria plugin renting e servizio renting abilitato in Voyager
NEW => TheSky64 → Aggiunta gestione controlli del nuovo TheSkyX a 64 bit della Software Bisque
NEW => TheSkyX/64 → Aggiunta gestione AO nel controllo camera
NEW => FilePattern → Aggiunto pattern $$SETTEMP$$ (riporta temperatura richiesta in sequenza come intero a due cifre senza segno)
NEW => FilePattern → Aggiunto pattern $$YY08$$ (riporta anno con stessa logica del pattern $$VOYDATEFOLDER08$$ )
NEW => FilePattern → Aggiunto pattern $$MM08$$ (riporta mese con stessa logica del pattern $$VOYDATEFOLDER08$$ )
NEW => FilePattern → Aggiunto pattern $$DD08$$ (riporta giorno con stessa logica del pattern $$VOYDATEFOLDER08$$ )
NEW => Tools → Introdotto in OnTheFly nuovo tool per l’ausilio nella rotazione manuale della camera alla Sky PA desiderata
NEW => Tools → Aggiunto campo di aggiustamento in modulo 90/180° nel tool per l’ausilio nella rotazione manuale della camera alla Sky PA desiderata
NEW => ASI Camera → Aggiornato Driver Voyager per camere ASI V2 all’SDK versione 1.17.0 del 2021.03.24 , si consiglia di installare almeno i driver di camera V3.16 del 2020.12.30
NEW => QHY Camera → Aggiornato Driver Voyager per camere QHY Beta all’SDK versione 2.3.13 del 2021.03.13
NEW => Tools → Introdotto doppia scala per il modo invertito nel tool per l’ausilio nella rotazione manuale della camera alla Sky PA desiderata
NEW => PHD2 → Introdotta gestione OPZIONALE cambio Profili di PHD2, si può ora associare un profilo di PHD2 al profilo di Voyager in modo che effettui lo switch automatico alla connessione del setup. I profili possono essere recuperati dal Setup di Voyager, tab Guiding, PHD2 Profile Selection
NEW => DragScript → Inserito nuovo Blocco Change Voyager Profile
NEW => DragScript → Aggiunto stato di abilitazione degli Eventi Di Emergenza (Exit, Suspend, Light) nella finestra della sezione DragScript
NEW => DragScript → Aggiunto nuovo parametro a linea di comando /rundefault per avviare un dragscript indicando solo il nome del file. Sarà cercato ed eseguito dall directory di default degli script utilizzata da Voyager
NEW => Sequence → Aggiunto Flag per attivare la ricalibrazione della guida ogni X minuti nel tab Guide-Dithering del configuratore Sequenza. Utile per chi ha montatura a forcella e sistema di derotazione attivo. La ricalibrazione della guida viene effettuata solo se la Sequenza gestisce anche la calibrazione della guida iniziale
NEW => Sequence → Aggiunto Flag per attivare il check obbligato ad ogni Realign target della tolleranza rotatore. Utile per chi ha montatura a forcella e sistema di derotazione attivo
NEW => Weather → Evidenziata l’eventuale disattivazione delle LIGHT Conditions nel widget di status del Weather, in caso di disattivazione delle LIGHT Conditions viene riportato tra parentesi anche lo stato di SAFE considerando le LIGHT Conditions
MOD => DragScript → Invio Mail tramite account Voyager, aggiornato il protocollo TLS a 1.2 in quanto il provider di servizi a breve non accetterà più livelli inferiori
MOD => DragScript → Aggiunta possibilità di indicare variabile decimale come valore di rotazione del Rotatore
MOD => FIT → Modificato il carattere di NULL della Header Unit per aderire allo standard FIT (Errore di caricamento in AstroPixelProcessor)
MOD => DragScript → Durante l’esecuzione del Repeat Block for N Times il numero di ripetizione attuale viene ora evidenziato insieme al numero di ripetizioni totali richieste
MOD => Cambiato in asincrono il metodo di connessione al socket dell’Application Server di Voyager per evitare dead lock delle connessioni del FITViewer in caso di assenza di Voyager
MOD => TheSkyX/64 → Modificato metodo di homing della AO
MOD => DragScript → Reso obbligatoria selezione di Eventi ABILITATI / DISABILITATI in caso di avvio del DragScript da Blocco personalizzato
MOD => Wait Safe → L’azione Wait Safe è stata adeguata all nuova gestione delle LIGHT Conditions introdotta con questa versione
MOD => Distributed Safe → L’azione Distributed Safe è stata adeguata all nuova gestione delle LIGHT Conditions introdotta con questa versione
BUG => Array → In caso di elemento dell’array disabilitato il sinottico delle esposizioni in sequenza del nodo 3 non veniva visualizzato
BUG => Array → In caso di elemento dell’array disabilitato alcune funzioni di del tab Utility e del tab Nodes fallivano o eseguivano comandi su Nodi errati
BUG => Array → In caso di elemento dell’array disabilitato o disconnesso la sequenza poteva fallire o generare warning ed errori non desiderati
BUG => SkyFlat → Non veniva utilizzato il parametro Flat Altitude nei settaggi generali degli SkyFlat. In ogni caso si consiglia vivamente di non modificarlo e lasciarlo al valore di default di 75°
BUG => DragScript → In alcune condizioni il restart autoamtico del Dragscript dai blocchi interni non azzerava le condizioni di override dell’avvio precedente se esistenti portando a malfunzionamenti
BUG => DragScript → In alcune condizioni Anche se disabilitata la gestione del LIGHT conditions nel weather veniva comunque utilizzata per il calcolo finale dello stato di SAFE
