Manual Download direct link:
https://www.starkeeper.it/voyager/Voyager_Setup_2.3.3.zip
Dropbox link:
https://www.dropbox.com/s/wvuerbmws0x1t7e/Voyager_Setup_2.3.3.zip?dl=1
Release 2.3.3 - Built 2021-07-07 - UPDATE INFO
NEW => Application Server → Added RemoteGotoAltAz remote command to the Application Server to remotely perform the altazimuth aiming of the mount
NEW => Application Server → Added RemotePulseGuide remote command to the Application Server to remotely perform an impulse driving movement with configurable direction and duration
NEW => Application Server → Added DonutsCalibrationRequired, DonutsCalibrationStart, DonutsCalibrationDone, DonutsCalibrationError events to the Application Server to manage the DONUTS scientific suite
NEW => Application Server → Added DonutsRecenterRequired, DonutsRecenterStart, DonutsRecenterDone, DonutsRecenterError events to the Application Server to manage the DONUTS scientific suite
NEW => DragScript → Insert new UDP TX block To send string data to an IP, UDP port
NEW => DragScript → Insert new UDP TX block To send binary data to an IP, UDP port
NEW => Rotator → Added RCOS TCC Rotator as a native rotator control
NEW => DragScript → Added new Donuts Calibration Block
NEW => OnTheFly → Added new Donuts Calibration command in Utilities
NEW => Sequence → New flag to manage the Donuts initial calibration in Sequence
NEW => Sequence Startup Override → Added possibility to exclude Donuts calibration with the start of Sequence in override
NEW => Sequence → New flag for managing the Donuts Recenter in Sequence
NEW => Donuts → New implementations and bug fixes
NEW => Emergency Events → Added source and string of the Weather system in the message of execution of EXIT and SUSPEND events, both on screen and in the logs
NEW => Emergency Events → Added environment variables in DragScript (see list in dragscript editor, dedicated window in toolbar) to obtain the date and time of the last emergency event generated since Voyager is active and the source and weather string if present and necessary
NEW => Donuts → Added new command RemoteSetDonutsMode to activate the sending of the ControlData event to the client
NEW => DragScript → Added new TSX Camera-FW Reconnect block
NEW => PHD2 → In addition to the automatic local connection, the possibility to select host name and communication port has now been added
NEW => Files → Added cleaning of files and Logs of the Dispatch process of images dedicated to the web dashboard
NEW => Files → Added FITViewer file and log cleaning
NEW => DragScript → Added new Update Decimal From Camera Temperature Block
NEW => DragScript → Added possibility to retrieve the coordinates from the sequence file for the DO IF HA BETWEEN block
NEW => DragScript → Added possibility to retrieve the coordinates from the sequence file for the DO IF ALTITUDE block
NEW => DragScript → Added possibility to retrieve coordinates from sequence file for DO IF ALTITUDE BETWEEN block
NEW => DragScript → Added possibility to retrieve the coordinates from the sequence file for the DO IF AZIMUTH BETWEEN block
NEW => DragScript → Added possibility to retrieve the coordinates from the sequence file for the WAIT ALTITUDE block
NEW => Planetarium → New Stellarium planetary control added (you need to activate the remote control and make it active when starting the Stellarium configuration)
NEW => Observing Conditions → Added option to remove the data of Temperature, Humidity, Dew Point and Pressure internal to observing conditions and keep those coming from other external controls / hardware
NEW => DragScript → Inserted a new environment variable of type Counter where the reason for the exit by error of the last sequence executed in DragScript is reported - $$ SEQUENCE_FAIL_STATUS refer to the wiki for the numerous values ​​it can assume
NEW => DragScript → The possibility to retrieve the coordinates from the sequence file for the various blocks has also been extended to the Voyager Array sequences
NEW => FITViewer → Added the ability to filter the original names of auto opened files to save the JPG
MOD => DragScript → Optimized the DragScript loading time
MOD => DragScript → Optimized DragScript startup time
MOD => Application Server → The results of remote actions were sent to all clients instead of just the client that requested the command
MOD => Rotator => The ASCOM drivers of the rotators that do not have the implementation of the CanReverse method are also managed, with these rotators it may not be possible to manage the Sky PA but only the Rotator PA (Mechanical PA)
MOD => Ascom Cover Calibrator Device → Managed drivers with method problems not protected by null reference
MOD => Autofocus → Added filter information related to autofocus in the Voyager log file
MOD => Donuts → Changed calibration timeout to 1500s
MOD => SkyFlat → Strengthened Dawn / Dusk time interval output control in case of incorrect configuration of the shooting parameters and average calculation by the user
BUG => RoboClip → PA angles outside the 0-360 ° range were mistakenly accepted
BUG => Sequence Configuration → The PA <= 0 ° and> = 360 ° have been brought back to the correct interval to avoid an unhandled exception in the code
BUG => FlatDevice → All the blocks with flat device operations were not executed correctly if only the flat device was connected, it was necessary to connect all the setup
BUG => Array → In the Array sequence configuration it was not possible to select drive time 0 for automatic
NEW => Application Server → Aggiunto comando remoto RemoteGotoAltAz all’Application Server per effettuare da remoto il puntamento in altazimutale della montatura
NEW => Application Server → Aggiunto comando remoto RemotePulseGuide all’Application Server per effettuare da remoto uno spostamento di guida ad impulsi con direzione e durata configurabili
NEW => Application Server → Aggiunti eventi DonutsCalibrationRequired, DonutsCalibrationStart, DonutsCalibrationDone, DonutsCalibrationError all’Application Server per gestire la suite scientifica DONUTS
NEW => Application Server → Aggiunti eventi DonutsRecenterRequired, DonutsRecenterStart, DonutsRecenterDone, DonutsRecenterError all’Application Server per gestire la suite scientifica DONUTS
NEW => DragScript → Inserito nuovo Blocco UDP TX Per inviare dati stringa ad una IP, porta UDP
NEW => DragScript → Inserito nuovo Blocco UDP TX Per inviare dati binari ad una IP, porta UDP
NEW => Rotator → Aggiunto RCOS TCC Rotator come controllo rotatore nativo
NEW => DragScript → Inserito nuovo Blocco Donuts Calibration
NEW => OnTheFly → Aggiunta nuovo comando Donuts Calibration in Utilities
NEW => Sequence → Nuovo flag per la gestione della calibrazione iniziale di Donuts in Sequenza
NEW => Sequence Startup Override → Aggiunta possibilità di eseguire l’esclusione della calibrazione di Donuts con l’avvio di Sequenza in override
NEW => Sequence → Nuovo flag per la gestione del Recenter di Donuts in Sequenza
NEW => Donuts → Nuove implementazioni e risoluzione Bug
NEW => Emergency Events → Aggiunta sorgente e stringa del Weather system nel messaggio di esecuzione degli eventi di EXIT e SUSPEND, sia a video che nei log
NEW => Emergency Events → Aggiunte nel DragScript variabili d’ambiente (vedi lista nell’editor del dragscript, finestra dedicata in toolbar) per ottenere la data ora dell’ultimo evento di emergenza generato da quando Voyager è attivo e la sorgente e la stringa meteo se presente e necessaria
NEW => Donuts → Aggiunto nuovo comand RemoteSetDonutsMode per attivare l’invio dell’evento ControlData al client
NEW => DragScript → Inserito nuovo Blocco TSX Camera-FW Reconnect
NEW => PHD2 → Oltre alla connessione automatica in locale è stata ora aggiunta anche la possibilità di selezionare nome host e porta di comunicazione
NEW => Files → Aggiunta pulizia file e Log del processo di Dispatch delle immagini dedicate alla web dashboard
NEW => Files → Aggiunta pulizia file e Log del FITViewer
NEW => DragScript → Inserito nuovo Blocco Update Decimal From Camera Temperature
NEW => DragScript → Inserita possibilità di recuperare le coordinate dal file di sequenza per il blocco DO IF HA BETWEEN
NEW => DragScript → Inserita possibilità di recuperare le coordinate dal file di sequenza per il blocco DO IF ALTITUDE
NEW => DragScript → Inserita possibilità di recuperare le coordinate dal file di sequenza per il blocco DO IF ALTITUDE BETWEEN
NEW => DragScript → Inserita possibilità di recuperare le coordinate dal file di sequenza per il blocco DO IF AZIMUTH BETWEEN
NEW => DragScript → Inserita possibilità di recuperare le coordinate dal file di sequenza per il blocco WAIT ALTITUDE
NEW => Planetario → Aggiunto nuovo controllo planetario Stellarium (occorre attivare il controllo remoto e renderlo attivo all’avvio in configurazione di Stellarium)
NEW => Observing Conditions → Aggiunta opzione per rimuovere i dati di Temperatura, Umidità , Dew Point e Pressione interni alle observing conditions e mantenere quelli provenienti da altri controlli/hardware esterni
NEW => DragScript → Inserita nuova variabile ambiente di tipo Counter dove viene riportato il motivo dell’uscita per errore dell’ultima sequenza eseguita in DragScript - $$SEQUENCE_FAIL_STATUS far riferimento al wiki per i numerosi valori che può assumere
NEW => DragScript → La possibilità di recuperare le coordinate dal file di sequenza per i vari blocchi è stato esteso anche alle sequenze di Voyager Array
NEW => FITViewer → Aggiunta la possibilità di filtrare i nomi originali dei file auto aperti di cui salvare il JPG
MOD => DragScript → Ottimizzato il tempo di caricamento del DragScript
MOD => DragScript → Ottimizzato il tempo di avvio del DragScript
MOD => Application Server → I risultati delle azioni remote venivano inviati a tutti i client invece che al solo client che aveva richiesto il comando
MOD => Rotator => Gestiti anche i driver ASCOM dei rotatori che non hanno l’implementazion del metodo CanReverse, con questi rotatori si potrebbe non avere la possibilità di gestire la Sky PA ma solo la Rotator PA (PA Meccanica)
MOD => Ascom Cover Calibrator Device → Gestiti driver con problemi di metodi non protetti da null reference
MOD => Autofocus → Aggiunte informazioni filtro relativo all’autofocus nel file di log di Voyager
MOD => Donuts → Modificato timeout calibrazione a 1500s
MOD => SkyFlat → Irrobustito controllo uscita intervallo temporale Dawn/Dusk in caso di errata configurazione dei parametri di scatto e calcolo media da parte dell’utente
BUG => RoboClip → Venivano erroneamente accettati angoli di PA al di fuori dell’intervallo 0-360°
BUG => Sequence Configuration → Ricondotte a corretto intervallo le PA <= 0° e >=360° per evitare un’eccezione non gestita nel codice
BUG => FlatDevice → Non venivano eseguiti correttamente tutti i blocchi con operazioni di flat device se era connesso il solo flat device, occorreva connettere tutto il setup
BUG => Array → Nella configurazione della sequenza Array non era possibile selezionare tempo di guida 0 per automatico
