Manual Download direct link:
https://www.starkeeper.it/voyager/Voyager_Setup_2.3.7.zip
Release 2.3.7 - Built 2022-12-16 - UPDATE INFO
NEW => RoboTarget Manager-> Added Max Sequence Time Constraint [T] to not have single sequences longer than the indicated time
NEW => RoboTarget Manager-> Added OneShot Constraint [U] to have single execution targets at the indicated time and time and early time if necessary (they interrupt all other targets)
NEW => RoboTarget β Managed OneShot Constraint [U] view the dedicated video tutorial
NEW => RoboTarget β Managed Constraint MaxTime [T]
NEW => Application Server β Added possibility to indicate not only the quality of the preview JPG images for the dashboard but also the maximum size in pixels
NEW => DragScript β Added new Abort RoboTarget Action Block to terminate the RoboTarget action voluntarily by the user if in progress
NEW => DragScript β Added new Block Abort RoboTarget Running Target to terminate the current Target in the RoboTarget Action and possibly also apply a suspension in minutes
NEW => RoboTarget β Added possibility to override Cooling Set Point, Guiding Exposure Time, Wait Between Shot with values dedicated to the target
NEW => Advanced NDA β Modified API dedicated to targets with new overrides
NEW => RoboTarget Manager-> Added Preset Time Interval Constraint [V] to have executable targets in absolute priority to execute in the indicated time interval and early time if necessary (interrupt all other targets except OneShots)
NEW => RoboTarget β Managed Constraint Preset Time Interval [V] view the dedicated video tutorial
NEW => Application Server β Added the TimeInfoUTC field to the NewJPGReady event with the date and time of the image in UTC format
NEW => ATTENTION !! Updated ASI Camera V2 SDK to version 1.26.0.0 of 2022.08.04 , Recommended installation of camera drivers V3.20 of 2022.10.18 - Then check the Remove Overscan Area settings if used
NEW => ATTENTION !! Updated QHY CMOS Camera Beta SDK to Ver. 22.8.24.10, Recommend installation of Beta camera drives Ver. 2022.08.17 - Then check Remove Overscan Area settings if used
NEW => DragScript β Added a new String type environment variable where the name of the currently loaded Voyager profile is reported - $$VOYAGER_PROFILE_NAME
NEW => Application Server β Added new RemoteGetStatus command to get Voyager operational status
NEW => Array β Added new condition block DragScript DO IF NODE FREE to run conditionally only if the queried node is in IDLE application state. Warning improper use of this block could cause damage !!!
NEW => Array β Added new DragScript condition block NODE EXCUTE DRAGSCRIPT ASYNC to execute Asynchronously (WITHOUT WAITING, just launch) a self contained DragScript in a remote node. Warning improper use of this block could cause damage !!!
NEW => Array β Added new DragScript condition block NODE ABORT RUNNING ACTION to abort any running action in the remote node. Warning improper use of this block could cause damage !!!
NEW => Application Server β Added information about the DOME control in the Control Data event
NEW => DragScript β Added new Block Empty Voyager Temporary Folder to empty all Voyager temporary folders without restarting the application
NEW => RoboTarget Manager-> Extended the Preset Time Interval [V] to have a number of multiple intervals for the same target
NEW => Advanced NDA β Target management APIs now also manage multiple Preset Time Intervals
MOD => RoboTarget β In case of exiting the action with SKIPPED status then the PDF report is not generated if it was required to avoid empty reports
MOD => RoboTarget β Removed the minimum duration constraint of the Sequence in case of Target in ONESHOT Mode
MOD => RoboTarget β In case of Target Sequence below the minimum allowed, the REJECT text is now displayed in the ROBOTARGET section
BUG => RoboTarget β In case of copy and paste of a target, in some cases all the targets of the copy recipient Set were hidden from the management. Bug Introduced with version 2.3.6a
BUG => Viking β I/O cards with more than 20 Digital Inputs generated an error reading the states received from Viking
BUG => RoboTarget Section β Ephemeris graphs lost information become black during RoboTarget execution (remember that Ephemeris data are valorised only when executing RoboTarget Scheduler)
