Web Dashboard 1.0.12 question
I am woking on the web dashboard and setting the bin level between 1x1 and 2x2. I wondered if the FOV indicator took binning into account for the FOV display? Initial tests on my part says no but I may be missing a step in my process for getting it to display with the changed binning.
Hi George,
the binning level not alter the FoV size, because the sensor size remain the same, so your FoV in unchanged if you work at 1x1 or 2x2 or more binning level.
The only thing that changes with binning is the sampling.
I hope I’ve answered your question.
Best
Fra
You explained it very well. Thanks. I was not certain so better to ask.
