In this version:
NEW => Now the input field IP / Hostname saves the last entry in the local browser
NEW => Version also hosted locally in next Voyager release 2.2.1 by an internal web server that will let you use the dashboad with and without an internet connection, when started from Lan.
Why do you have to enter IP address in browser? I didn’t have to do this. I just go to Web Dashboard and entered my laptop’s IP address where Voyager is running in IP/Hostname box and click on CONNECT button and it works.
OK. What purpose does it serve to run Web Dashboard on the same PC that’s running Voyager? I am not sure I understand how his instructions help to run Web Dashboard from Android, Apple or other devices. I understand the purpose of having port 80 to be able to run Web Dashboard without connecting to the internet.
If you did not have internet access and wanted to use the dashboard. I have my Voyager MiniX PC running now, and I am in my office connected to the local copy of the dashboard.
Finally got it working. I didn’t realized I had to enter my laptop’s IP address where Voyager is running on other devices. Once I entered my laptop’s IP address on other devices like Android tablet or phone, it worked. I tested by disconnecting UVerse cable from UVerse modem so there’s no internet connection.
This is great. I brought it up on my phone last night, sat down and watched TV for a bit. Got the warnings for star lost with the guiding (in the logs), and sure enough, the clouds had rolled in. Simple enough then to walk outside and shut everything down.
Hi Max, if you hit abort or disconnect buttons the dashboard will show a warning modal message, that require a second hit on another button to continue.
Please give a try and let me know.
F
Few problems here for Tony – mostly related to the hidden profile folder which did not allow for saving. Once that was fixed and we switched the Chrome from Edge – he is in business.
