hello,
I’m testing voyager via the demo 45 day license :
- Under Cameras and filter wheel. I understand that there is now direct support for FLI equipment although I wasn’t listed.
- I don’t have access to some of my equipment right now. From what I have seen, the best way to organise the precise position per target is via the web dashboard and using the framing option (including rotation and mosaics). However, as my ASI camera is not connected, my profile doesn’t include the CMOS size. This makes it impossible to use the framing tool. Is there a manual wait to input such data.
- rotation. Is there a definition of how P.A. is calculated. Is the standard point for a camera aligned on a German equitorial mount to have PA 0 degrees or 90 degrees ?
Thank you
