I’m starting to get an array system up and running and want to measure my filter offsets. What better way than to use Dragscript to automate it! I’ve cycled through my 7 filters 3x with a RoboStar focus on each filter, followed by a 10s image.
Since the focus position is stored in the FITs header, I use my planner/inspector app to check the consistency of the positions and their offset. You can see some pattern in the focus position where there’s a slight shift to lower focus positions. This is presumably due to the scope continuing to cool through the experiment.
I can also export these data in the inspector into a csv file and compute the offsets from there (I use pandas, but excel works just as well).
