I have switched over to the 64bit version of TheSkyX. I changed my Setup profile to reflect the TheSkyX64 selection for the Mount, Camera Add-on, Platesolve, and Planetarium. When I try to connect I get the following errors:
ATTENTION ! Voyager cannot run all functionality !!!
09:50:40 016 - Camera Connection Error = Exception Error : Object reference not set to an instance of an object.
Telescope Connection Error = Retrieving the COM class factory for component with CLSID {27D7CF37-1CB7-4307-8D89-ABF7F02B7A64} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
Guide Connection Error = PHD2 Set Connected Command Timeout : Timeout of 10[s] reached.
Planetarium Connection Error = Retrieving the COM class factory for component with CLSID {0E0015B2-8EB6-4CA1-8A19-1A8BA6540C64} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
I have run TheSkyX64 stand alone and all of my equipment connects and functions properly.
What am I missing or doing wrong. Voyager and the old 32bit version of TheSkyX worked perfectly.
